Saefrog
Topic: Stereo drains battery and won’t turn off Posted: 15 Mar 2018 at 1:30pm |
I just bought a new 2017 Rpod. I noticed when you turn the stereo off a clock is displayed, thus still draining the battery. I know enough about stereos that this will drain a battery in 30-60 days and destroy it. Whenever i flip all the breakers it still stays on. Any advice on how to turn the clock completely off during storage?
marwayne
Posted: 15 Mar 2018 at 1:39pm |
The radio is not the only draw there is also the CO and LP detector, put in a battery cut off switch.
crw8sr
Posted: 15 Mar 2018 at 1:40pm |
Welcome and congratulations on your R-pod.
Put a battery shut off on your battery. Several posts here on the forum on how to accomplish it.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
Posted: 15 Mar 2018 at 4:01pm |
A) Flipping the breakers does nothing to any of the 12v items. B) Disconnect your battery, either by removing a cable, or by adding a battery cutoff switch.
seafans
Posted: 15 Mar 2018 at 7:42pm |
Another item that drains the battery is on some of the new
three way refrigerators the gas valve is an electric solenoid that is
electrically engaged as long as the gas portion of the refrigerator is
operating. The best results with the battery during storage is to remove
it and if you can put a trickle charger on it at have or at least on charge
once or twice a month.
Saefrog
Posted: 15 Mar 2018 at 7:50pm |
Great advice! Thank you guys!
Larry-D
Posted: 16 Mar 2018 at 5:59pm |
Or just remove the positive cable from the battery
Posted: 16 Mar 2018 at 6:05pm |
Yep, if trailer is in storage - why not pull battery, take it back to house and trickle charge until your season begins. If it is in storage with no charge capability why have a battery in it.
ribet
Posted: 16 Mar 2018 at 8:58pm |
Always remove the negative side first. Safer and no way to short out or make a spark.
Saefrog
Posted: 17 Mar 2018 at 7:43am |
I might not use my camper for a couple of months which would drain the battery so I was thinking of a quick way to kill the power to the battery.
