mpraphael
Topic: Best replacement for broken stabilizer jack on 178 Posted: 28 Apr 2019 at 1:29pm |
Hi,
One of the rear stabilizer jacks on our 178 was destroyed when backing up. Is there a brand of replacement jacks that is most recommended? (Ha, wouldn’t you know we just discovered the broken jack when we’re getting the rpod ready to sell...great timing.)
Thank for your help!
Megan and Peter
Northern Michigan
mjlrpod
Posted: 28 Apr 2019 at 2:32pm |
There are several replacements available. I've seen some at walmart. If you were keeping it, I'd recommend using the " sav a jack" system that lets you take the stabs off when not in use.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
mpraphael
Posted: 28 Apr 2019 at 2:36pm |
Thanks so much for your speedy reply.
Megan and Peter
Northern Michigan
Jholler
Posted: 28 Apr 2019 at 3:36pm |
+1 for sav a jack! Here is what I installed on my 179, works perfectly.
https://www.amazon.com/gp/aw/d/B00IKKS4MS?psc=1&ref=ppx_pop_mob_b_asin_title
https://www.amazon.com/gp/aw/d/B005CJOR1M?psc=1&ref=ppx_pop_mob_b_asin_title
2015 rpod 179
2014 Ram ecoDiesel HFE
2009-ish Chihuahua
Kevinscamps
Posted: 29 Apr 2019 at 3:02pm |
I saw someone who just took out the bolts that hold on the jacks and replace with cotter pins for easy removal.
Jholler
Posted: 29 Apr 2019 at 7:08pm |
If you can do that, yeah. Mine were spot welded on.
2015 rpod 179
2009-ish Chihuahua
GlueGuy
Online Status: Online
Posted: 29 Apr 2019 at 7:27pm |
Originally posted by Jholler
If you can do that, yeah. Mine were spot welded on. |
Yeah. Ours too. When I first looked at Save-a-jack, I discovered that I would need an angle grinder or something similar to get the jacks off in the first place.
Jholler
Posted: 30 Apr 2019 at 10:37am |
Harbor freight had a cheap one. 😎
You can get the old ones off easily by wiggling them back and forth, the welds will break. To smooth off the slag and get a good flat surface for the next one you'll need a grinder though.
2015 rpod 179
2009-ish Chihuahua
mpraphael
Posted: 30 Apr 2019 at 8:22pm |
Thanks!
Megan and Peter
Northern Michigan
mpraphael
Appreciate the response!
Megan and Peter
Northern Michigan
