Floor Sagging by John Marucci |
Post Reply | Page 12> |
rpod190
Groupie Joined: 07 Apr 2019 Location: Illinois Online Status: Offline Posts: 45 |
Post Options
Quote Reply
Topic: Floor Sagging by John Marucci Posted: 04 Dec 2020 at 8:33am |
I follow this gentleman and his woes with his Rpod. Having the kitchen in the back puts more stress on the floor whereas my RP190 has only a table and no walking around weight that the models have with a kitchen in the back. Please take a look at John's videos on his rpod and this efforts to get FR to do something. He has alot of good information. Subscribe and get more knowledge & power. Buying An RV During Unprecedented Times - 5 Cautionshttps://www.youtube.com/watch?v=G4JXAApykTc
Wynnster
mjlrpod
Post Options Quote Reply Posted: 04 Dec 2020 at 2:22pm |
John is a member here, and posts fairly often. I wouldn't say he has woes with his pod, but he's had a few things happen.
2017.5 Rp-172
Pod People
Senior Member Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1068 |
Post Options Quote Reply Posted: 04 Dec 2020 at 3:48pm |
Several of 179 owners have followed his advice and installed floor braces similar to what the factory has done. Vann
rpod190
Post Options Quote Reply Posted: 05 Dec 2020 at 6:56pm |
I have enjoy his posts and I will continue to follow him. Keep up the good work John!
Wynnster
rawest50
Post Options Quote Reply Posted: 30 Mar 2021 at 9:13am |
Anybody know about how much throat fix is costing? My are sagging.
2017.5 RPod 179
Post Options Quote Reply Posted: 30 Mar 2021 at 10:11am |
Throat fixes are expensive. Ask your otolaryngologist for a quote before agreeing.
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6297 |
Post Options Quote Reply Posted: 30 Mar 2021 at 11:22am |
The fix involves finding someone to fabricate a brace for you. The materials are not too expensive. The expensive part is geting it cut and welded to the right dimensions. with plates drilled so the brace can be installed. It has to be the width between the frame which may vary by a little, so measure carefully so it will go in and not leave any big gaps between the plate and frame. If you want it powder coated, that will be extra. Mine came unpainted, so I had to wire brush it and then paint it. Some prices will vary depending on whether you can do the welding yourself or whether you need to find a metal shop to do the work. Total should still come to under $100. You can use the same type #14 self-drilling/tapping screws used by FR in the rest of the braces to install it.
rawest50
Post Options Quote Reply Posted: 30 Mar 2021 at 1:39pm |
Yep.
2017.5 RPod 179
SPrins
Newbie Joined: 22 Jan 2021 Location: TN Online Status: Offline Posts: 2 |
Post Options Quote Reply Posted: 26 Jan 2022 at 3:37pm |
I will be doing a variation of this repair later in the spring. Will document with photos as we move along. I plan on making a grid of sorts using 1.5 inch square tubing and a sheet of 1 inch PVC sheeting. This way I do not have to worry about wrapping the sheeting to prevent water damage.
I will also be bracing the floor that extends over the frame below the slide out. I will be using 3 pieces of 1/4" thick angle iron 3 x 5 inches that is 12 inches long. Will also post pics of that project as well. I do not believe I have either of these issues occurring with my 2018 - 179; but am taking a very proactive approach to make these items non issues. |
2018 R-Pod 179
2020 Ford F-150 3.5L Ecoboost |
PilotPodder
Senior Member Joined: 04 May 2016 Location: Portage, MI Online Status: Offline Posts: 305 |
Post Options Quote Reply Posted: 26 Jan 2022 at 7:36pm |
If I were to do it over, I would likely go with the aluminum brace displayed in this video:
