Ordering parts |
richardd
Groupie Joined: 09 Feb 2017 Online Status: Offline Posts: 61 |
Post Options
Quote Reply
Topic: Ordering parts Posted: 19 Apr 2022 at 7:11pm |
Anybody know the nearest R-pod dealer to Charleston SC, for ordering parts?
campman
Senior Member Joined: 26 Mar 2021 Location: La Salle, MB Online Status: Offline Posts: 209 |
Post Options Quote Reply Posted: 19 Apr 2022 at 8:11pm |
Hello richardd. Just saw your question and found this site. A dealer locator should do the trick for you.
https://forestriverinc.com/rvs/dealer-locator/r-pod Good luck in your parts ordering/finding! Andy |
Andy and Laurie
'16 F150 5.0 4X4 w/factory tow pkg '21 RP192 "If the women don't find you handsome...at least let them find you handy!" Red-Green |
SC for Huskers
Senior Member Joined: 22 Feb 2017 Location: Goose Creek, SC Online Status: Offline Posts: 144 |
Post Options Quote Reply Posted: 19 Apr 2022 at 8:15pm |
Got my Rpod from John's in Columbia and the Forest River website says there is a dealer in Conway. I would think most items can be purchased or ordered from any RV dealer. |
Happy Traveling,
Tom 2017 172pod 2011 F150 STX |
richardd
Post Options Quote Reply Posted: 20 Apr 2022 at 3:58pm |
I just spoke with John's parts man. He said the light I'm looking for is obsolete. The problem I'm having is the light in my Dometic fridge, has developed some corrosion from moisture on the connections. I can clean it off and it works for awhile, but eventually it starts beeping. I would like to find that light assembly, or a suitable replacement. I'm currently using an attached motion sensor light, which works, but I have to keep charging it. You would think that if the light is obsolete they would offer a replacement but don't know if they do.
lostagain
Post Options Quote Reply Posted: 20 Apr 2022 at 6:28pm |
You might want to contact the Dometic parts people. They sell independently of Forest River dealers.
Also, if you can get it cleaned up enough to get it working again, consider slopping dielectric grease all over the parts that get corroded due to the moisture. It is a silicone based grease that keeps the moisture off the corrodible parts. Here is one of many listed in Amazon: https://www.amazon.com/Permatex-22058-Dielectric-Tune-Up-Grease/dp/B000AL8VD2/ref=sr_1_7?crid=NNBTX8TT3CQV&keywords=dielectric+grease+for+electrical+connectors&qid=1650497211&sprefix=dielectr%2Caps%2C79&sr=8-7
richardd
Post Options Quote Reply Posted: 20 Apr 2022 at 7:06pm |
Thanks Fred, believe it or not, I did try the silicone grease but didn't seem to work. The little connectors are covered with a gold looking substance (maybe brass) except for a couple which I scraped off with a knife. It's working now, so I'll wait and see if it beeps again. In the mean time I'll Google Dometic parts. Thanks alot.
Post Options Quote Reply Posted: 20 Apr 2022 at 8:34pm |
Also, put a little drip loop in the wire leading to the light from the back of the refrigerator. It will help keep condensation water from running directly down the wire to the connections.
