Axle-less suspension with 4" lift |
gpokluda
Senior Member Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 279 |
Post Options
Quote Reply
Topic: Axle-less suspension with 4" lift Posted: 02 May 2023 at 6:22pm |
Just saw this in an email from etrailer. Looks really interesting.
https://www.etrailer.com/Trailer-Axles/Timbren/ASR35HDS02.html
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Triumph T120 |
hank*pod
Groupie Joined: 06 Oct 2022 Location: PA Online Status: Offline Posts: 61 |
Post Options Quote Reply Posted: 02 May 2023 at 10:46pm |
It says 4" lift but it also says "keeps trailer deck height the same." I'm not sure I can reconcile those two. Presumably you can increase ground clearance since you'd mount the required 2" square crossmember higher than the torsion axle but the deck height remains the same?
GlueGuy
Post Options Quote Reply Posted: 03 May 2023 at 9:55am |
That would require some serious reinforcement of the frame where it attaches.
hank*pod
Post Options Quote Reply Posted: 03 May 2023 at 11:50pm |
It does require a cross brace be procured and installed between the two assemblies; presumably it's designed not to torque the frame rails.
