Surge Protectors |
deborahy30004
Newbie Joined: 26 Nov 2011 Location: Tennessee Online Status: Offline Posts: 1 |
Topic: Surge Protectors Posted: 06 Dec 2011 at 12:22pm |
We purchased a 2010 R Pod 171. We will be camping for 8 days in Tennessee in a couple of weeks. New to Rving. We're wondering about surge protectors. Will those who use them share the makes/models/stories? Thanking you in advance.
Deb4Crows 2010 R Pod 171 2002 Ford Explorer
Guests
Guest Group |
Posted: 06 Dec 2011 at 12:42pm |
Welcome to the group!
I can't answer your question as I do not use a surge protector - but I like to live dangerously!
I have a whole house protector at home along with individual protectors at each "sensitive electronics" type devise. So, I do believe they are quite valuable. While camping, most everything I use is 12 volts. I don't use the microwave. That leaves the water heater and A/C. I just turn those on as needed. So far, my gamble has worked in my favor.
psaman
Senior Member Joined: 26 Jun 2010 Location: Corpus Christi Online Status: Offline Posts: 231 |
Posted: 06 Dec 2011 at 12:50pm |
David, since the water heater also runs on propane, does it also need shore power to run the electronics or is 12v enough ? I was also wondering about the heater.
2011 R-177 "Sponge-Pod"
2011 F-150 XLT "Texas Edition" |
Posted: 06 Dec 2011 at 2:18pm |
Welcome. I recommend buying a Kill-A-Watt meter and keeping it plugged in where you will see it in your pod so you can monitor the voltage. On my 171 there is an outlet directly below the sink which I can see every time I open the door. The biggest problem in campgrounds is voltage sags and not spikes - a surge protector will only help with spikes and only with the really big ones (lightning strikes, but not ones that are too close, then nothing will help). Keep an eye on the voltage through the day, especially during hot summer days. If the voltage goes below 110 volts turn off your A/C and don't use the microwave. Low voltage will kill them. The other AC appliances (TV, water heater element, converter) should be ok even in a voltage sag. On the other end, if the voltage goes above 130, you should unplug the entire pod until the problem improves. As for spikes, I wouldn't worry about it.
psaman, you can run the propane side of the water heater on just 12 volts. Even when you are plugged in the converter changes the 120 volts AC to 12 volts DC. The heater is the same - 12 volts. The electric element in the water heater requires 120 volts AC (you can use propane and AC at the same time to reheat the water faster).
Guests
Guest Group |
Posted: 06 Dec 2011 at 4:49pm |
Thanks Tech! I probably should have been more clear. I run the water heater on 120 volts when it is available - just to save my propane for primitive camping. When operating on propane, as Tech says, you only need 12 volts from the battery.
psaman
Posted: 06 Dec 2011 at 5:45pm |
David, not a problem and thanks Tech! |
Footslogger03
Posted: 06 Dec 2011 at 8:42pm |
We have a portable surge protector that we bought from Camping World 3 years ago. Here is the link:
http://www.campingworld.com/shopping/item/portable-30-amp-gfci-surge-guard-with-shock-shield/18337 We have had at least 3 instances when electrical storms hit whilemwe were camping. In all instances the surge protector tripped when the campground power surged and we had no damage to any electrical components. We wouldn't camp without one. Have considered getting a permanent/ built in model but were drivenoff by the price. We paid about $80 for ours and feel like it worth every penny MJ |
Livin' the Dream ...'Slogger
sfish
Senior Member Joined: 18 Sep 2011 Location: Bloomington Mn. Online Status: Offline Posts: 134 |
Posted: 06 Dec 2011 at 9:10pm |
I bought the ems portable surge protector from camping world. I didnt want to hard wire one into the unit . Who knows if it fails you wont have power and when you sell your unit you can take it and put it in the new one.
sjf
Footslogger03
Posted: 06 Dec 2011 at 9:13pm |
================== That was the second reason I didn't want the hard-wired surge protector. This one goes with us ... MJ |
