  New Posts New Posts RSS Feed: TV brake controller compatibility
Topic ClosedTV brake controller compatibility
CaperPodder View Drop Down
Direct Link To This Post Topic: TV brake controller compatibility
    Posted: 09 Aug 2013 at 12:59pm
Hi all,
Looking to upgrade to a bigger TV and noticed that some come with their own brake controller. Wondering if the brakes on my 2013 177 will be compatable with these controllers. Looking at 2103 F-150, 2013 Silverado/Sierra or a 2013 RAM.
Appreciate all your feedback.
Sleepless View Drop Down
Direct Link To This Post Posted: 09 Aug 2013 at 1:47pm
There should be no compatibility issues.
Bob
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
hogone View Drop Down
Direct Link To This Post Posted: 09 Aug 2013 at 1:52pm
definately go with FORD!!!
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Direct Link To This Post Posted: 09 Aug 2013 at 2:02pm
Welcome.  Yes, generally brake controllers are compatible with all electric brake systems from small one-axle utility trailers up to two-axle construction flatbeds.
Find out if the built-in controller is timer based or a proportional controller.  If it is the older-style timer type save your money and don't get that option.  For about $100 you can get a decent Prodigy, which uses the proportional technology.  That matches the braking response from the trailer to what you are doing with the brake pedal - if you hit the brakes in an emergency stop the trailer will immediately give you the same heavy braking, or if you just tap the brakes to slow down in heavy traffic then you'll just get a little braking.  The timer types tend to be "jerky" in slow traffic and never give you all they can in an emergency, because they just slowly give you more brakes up to the limit you've set.  You also have to fiddle with that limit control all the time which isn't true with the proportional type.
Folornhope View Drop Down
Direct Link To This Post Posted: 09 Aug 2013 at 9:36pm
I just upgraded to the 2013 F150, the factory brake controller is supposed to help with anti-sway by monitoring each wheels braking and adjusting the trailers brakes accordingly.  Check page 16 of the quick reference guide
Eddy the Escape Pod...177
Ford F150
Direct Link To This Post Posted: 11 Aug 2013 at 7:54am
Thanks everyone, we decided to go with the F-150. It is in transit from Michigan and should be here next week. We were feeling underpowered with our Mitsubushi Outlander. We will miss it but I will feel much more comfortable on those long trips with the new tv.
Don, Mimi, & Nola the Goldendoodle
2013 RPod 177 (CachePod)
2013 F-150 4x4
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 11 Aug 2013 at 10:05am
My 2010 F-150 handles the pod with no problems. I hardly know it is back there. And the factory controller is great.
Mine is an old fashioned V8, not Ecoboost. Let us know how yours does.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
TrinityTurret View Drop Down
Direct Link To This Post Posted: 16 Oct 2013 at 12:37pm
HELP! In negotiations with dealer on purchasing used Silverado 1500 to pull our 171. We currently have Dodge Caravan to trade in (has new brake controller, would have to put it on the Silverado). Dealer says and swears that everyone HE talks to says they pull 3,000 lb and larger trailers WITHOUT brake controller. He says he wouldn't even fool with trying to swap it out of the Caravan and install it in the Silverado..says the truck will pull the Rpod with ease and not need electric brakes of the trailer.
Is he wrong? Is he right? Help...I need to know before we make the trade decision!
There's only one way...
Direct Link To This Post Posted: 16 Oct 2013 at 12:44pm
Most state laws require operational brakes on trailers over 1500 pounds.  He is right about the truck being able to pull  the trailer without a controller, but he is absolutely wrong about not needing the controller.  Insist on swapping the controller to the Silverado.
Now for a disclaimer.  Does the Silverado towing package include a brake controller?  I am assuming that it does not.
Bob
Direct Link To This Post Posted: 16 Oct 2013 at 12:48pm
Thanks Bob. The truck comes with wiring, but not a built-in controller. Ours is a Tekonsha Primus IQ 90160.
