Near Des Moines, Iowa.
20 Foot Forest River R-Pod Travel Trailer, Model 179, 2014 model. The only R-Pod with lots of inside storage space.
This trailer weighs 2800 pounds and includes a convection microwave, refrigerator with small freezer, 2 burner LP stove, two 20 lb LP gas cylinders, short queen foam mattress, and has an 8 foot slide out containing the sofa, refrigerator and microwave/oven. The trailer also has an all-in-one shower bathroom. It is like-new condition. It also includes the R-Dome, which is an 8 by 10 screen room that attaches to the side of the R-Pod.
The trailer includes all possible R-Pod options including LED low energy lights, a 19 inch HD TV, a stereo CD and DVD player, and a 4 inch axle riser. An 1 1/4 inch hitch is located at the rear of the trailer for either the spare tire carrier or a bike rack.
In addition to the Luxury Interior and Exterior Packages from the dealer, the trailer has the following upgrades.
*Addition of a spare tire carrier that attaches to the frame just behind the LP tanks. This allows for the use of the hitch on the back as a bike carrier.
*Addition of a 12 volt outlet on the inside of the trailer for 12 volt appliances
*Addition of a tilting mount so TV can be viewed at a better angle from multiple locations
*Replacement of the original mattress with a Classic Dream 9" Engineered Latex Standard Top Mattress - Queen
*Includes an Eaz-Lift 48051 600 lbs Elite Bent Bar Weight Distributing Hitch with Adjustable Ball Mount and Shank
*Addition of a SHURflo 182-200 Pre-Pressurized Accumulator Tank and SHURflo 94-591-01 Pump Silencing Kit to the fresh water system to reduce water pump cycling and noise
*Addition of a Camco 43781 Wall Mounted Clock, hooks, a small basket, and shelving for convenient storage
*Addition of an extra storage tube under the front frame for the storage of a 20 foot sewer hose. Original storage tube only holds an eight foot hose.
*Addition of a pvc awning and extension poles. Awning fits into groove for the R-Dome and can be set up quickly when shade is needed. Much faster setup than the R-Dome.
Asking $13,900.00
