  New Posts New Posts RSS Feed: Can't get WH lit on LP
Topic ClosedCan't get WH lit on LP
Tim View Drop Down
Direct Link To This Post Topic: Can't get WH lit on LP
    Posted: 25 Jun 2016 at 3:22pm
The water heater works fine on AC, but it will not light on LP. I read on this great forum that when on propane only the inside switch is on, on AC both inside and outside are on. Is that correct? I hear it trying to light, but no go! Is there a gas shut off to water heater?
john in idaho View Drop Down
Direct Link To This Post Posted: 25 Jun 2016 at 7:00pm
Gas is turned on?  Burner on stove lights? No wasp nests or spider webs around H2O burner?
Tim View Drop Down
Direct Link To This Post Posted: 25 Jun 2016 at 9:00pm
Thanks! Yes, the gas is on, the stove works, no webs or nests.....I'm puzzled? I hear the click but no flame!
birderdiane526 View Drop Down
Direct Link To This Post Posted: 25 Jun 2016 at 9:19pm
Out of LP?
Diane and Michael
2007 Toyota Tundra
BLOG:Podding in Paradise,
birderdiane526.blogspot.com
Direct Link To This Post Posted: 26 Jun 2016 at 10:08am
Air in the line? It might take a few attempts before residual air is purged and the WH lights.The same thing goes for the refrigerator. This is the case even if the stove lights as they are different line branches.
Direct Link To This Post Posted: 26 Jun 2016 at 12:19pm
If it hasn't been run on gas in a while, it may take a few tries to light. If it's already hot because it's on elec. it won't light either.
JandL View Drop Down
Direct Link To This Post Posted: 26 Jun 2016 at 3:32pm
http://www.rvforum.net has some very good articles
Furnace_Trouble.pdf
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
WillThrill View Drop Down
Direct Link To This Post Posted: 26 Jun 2016 at 8:04pm
First of all, be sure that the anode is screwed into the water heater.
Second, be sure that the stove will actually light (it sounds like you have).
Third, be sure that the breaker that goes to the water heater is on (it sounds like it must be if you hear it clicking).
Fourth, leave the water heater switch turned on for several minutes.  It probably took mine a good three minutes left on to light for the first time after we pulled it from storage and winterization.
2014 Hood River 177
2005 GMC Envoy XL
mjh203 View Drop Down
Direct Link To This Post Posted: 14 Aug 2016 at 8:20am
I had the same problem and found that the igniter cable had come disconnected which can be accessed by removed a panel in the storage compartment right of the water heater (at least on my 178). I messed with this water heater for hours trying all of the tips and tricks mentioned in the forums and could not get it to work. See if you have this secret access panel!
