  New Posts New Posts RSS Feed: Mounting generator on Rpod
Topic ClosedMounting generator on Rpod
Megan View Drop Down
Direct Link To This Post Topic: Mounting generator on Rpod
    Posted: 29 Jul 2016 at 9:06pm
We purchased an eu3000is Honda generator for our 2010 R-pod and want to make a frame for it to mount on the rear of the rig. A mod has been made already where the tire was removed and a storage box bolted to the frame, so removing the box and widening the existing framework doesn't look like it would be too difficult to achieve.
However, both my hubby and I want to make sure the added 150lbs weighing down the back isn't going to create a towing problem.
Any advice, feedback, comments would be appreciated, as we want safety first.
Meg & Ken
JandL View Drop Down
Direct Link To This Post Posted: 29 Jul 2016 at 10:26pm
You might want to look at my post on the dynamics of towing and the problems of having to much weight to the front or rear of the trailer and how it affects sway (yaw)
http://www.rpod-owners.com/forum_posts.asp?TID=7315
Here is a good YouTube video on Caravan Stability Studies
https://www.youtube.com/watch?v=PFzrWHTG5e8
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
Direct Link To This Post Posted: 29 Jul 2016 at 10:33pm
Thank you! We will look these over carefully.
Meg & Ken
CharlieM View Drop Down
Direct Link To This Post Posted: 29 Jul 2016 at 10:38pm
In addition to Jandl's points I would add that mounting 150# on the moment arm necessary for the generator is a really bad idea. The back end of a trailer is a very harsh environment dynamically. The bouncing encountered there amplifies any road bump like the end of a bull whip. I would expect the bumper to fail and fall off pretty quickly with the obvious results. The original RPOD bumper specification was for 150# max right on the bumper and that was a reach. I believe FR has backed off on that now.
Direct Link To This Post Posted: 30 Jul 2016 at 12:15am
Plus there is the problem of vibration and noise with it mounted directly to the pod and also so close.  For these reasons I carry mine on the front of our TV.  http://rpod-owners.com/forum_posts.asp?TID=3689
A downside is it does block some airflow (but not visibility) so the engine runs warmer.
Direct Link To This Post Posted: 30 Jul 2016 at 12:40am
MDPaddlersPod View Drop Down
Direct Link To This Post Posted: 01 Aug 2016 at 8:47am
TechnTrek, would you please post a pic of your generator on the front of your TV. I have the same Honda 3000is generator and have been trying to figure out where to tow it. Thanks, Jim.
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
Direct Link To This Post Posted: 01 Aug 2016 at 10:51am
see the link I posted above.
Note marwayne's solution (above) includes using a jack to raise the generator off of the frame when in-use, which takes care of a lot of the vibration.  I'm debating testing something similar on the back of my camper.
