furpod,
I'm not sure I would have ever sprung for $1200 when the Enduro was full price. But now they are closing out that line, the $600 sale price is a little easier to swallow. I think the Enduro model is being replaced with a Ego model.
I have not tried the Enduro at a campsite yet, but it is awesome at my house. In order to keep the HOA Nazi happy I park my Pod beside a section of privacy fence that I installed on top of a 5 ft. high brick retaining wall behind my house as close as I can get to the basement garage door. To get there I have to back thru two 90 degree turns. Even with the Trailer Valet, getting the Pod parked close to the retaining wall/privacy fence meant cranking the Trailer Valet handle several turns then going over to the side of the Pod to make sure I was not going to hit the wall.
Every time I mow the yard I have to move the Pod so I can get the mower out. Then put the Pod back while I mow. Don't want to upset the HOA Nazi by having my Pod exposed for all the world to see!!
With the Enduro remote control moving the Pod is a piece of cake. I can walk around the Pod as I push buttons to move the Pod in whatever direction I need it to go.
One thing I did learn is it is extremely important that the rollers for each motor are positioned exactly the same distance from each tire. Not close to the same distance, but EXACTLY the same distance. They ship two small spacers to help get the rollers the same distance from the tires. If the rollers are not exactly the same distance, then when you are trying to move the Pod either straight ahead or straight backwards, it will vere slightly to the side where the roller is the slightest bit closer to the tire. (Ask me how I know that!!)
I am looking forward to camping at a waterfront site so I can use the Enduro to rotate the Pod so the entrance door side faces the water!! I have learned that if you hold the forward left & back right buttons at the same time, the Pod will rotate in a circle!!
