  New Posts New Posts RSS Feed: Seal under slideout
Topic ClosedSeal under slideout
Joan and John View Drop Down
Direct Link To This Post Topic: Seal under slideout
    Posted: 17 Aug 2016 at 9:43am
The rubber seal under the slideout has come out and sags down. Can't seem to get it back in the groove. Any advice? 2014 176T
john in idaho View Drop Down
Direct Link To This Post Posted: 17 Aug 2016 at 7:04pm
You might have to spray some silicone spray in the track and start at one end.  And slide along.  I can't recall but I think it is in a track.
hogone View Drop Down
Direct Link To This Post Posted: 18 Aug 2016 at 7:02am
mine does it every time; mainly in the middle by the gears.  ive taken it off a couple of times and slid it back on, but it still does it.  im able to snap at least the top back on track before closing slide for a good seal.  i lube a lot with silicone, but it doesn't keep it from coming off.  i think when im motivated, im going to put a new track and probably seal on(heck i havent even put my door window in yetEmbarrassed).  hogone
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Direct Link To This Post Posted: 24 Aug 2016 at 2:23pm
would it be a good idea to put adhesive behind it and then push it on? If so, what adhesive would you recommend?
