Hutch
Topic: adding usb ports and storage above radio Posted: 08 May 2017 at 6:57pm |
Pretty happy with the results of this project. Needed a place to charge phones, mifi, tablets etc, and found plenty of room above the radio for ports and a place to put the device while charging. Added switches to the voltmeter and charging ports for battery life and darkness at night. Hardest part was matching stain color with the cabinetry. Close enough, I guess.
Posted: 08 May 2017 at 7:46pm |
Very nice craftsmanship!
Wepod
Posted: 09 May 2017 at 6:44am |
looks nice. I tried matching the stain color too it is tricky what did you end up using?
jimandclare
Posted: 09 May 2017 at 7:05am |
Credit goes to Wood River Pod for this info. Go to your nearest Sherwin Williams and ask for a quart of "Jeff's Rpod Brown" in satin enamel. Really good match and it's in their computer. If you're looking for a stain, apply 3-4 coats of this, also from Sherwin Williams:
Jim & Clare
2016 R-pod 178
2014 Ford Edge
Posted: 09 May 2017 at 7:39am |
Yes, looks great, and, across all vintages of Pods.. stain matching is a pain. I did it manually a couple times.. I swore if I did any interior work on another Pod I hadn't already matched, I was going to make the owners paint.. LOL
voisj
Posted: 13 May 2017 at 11:49pm |
Hutch, nice!! I have taken my radio out a few times and thought about doing something with the empty space above it. This is a winner!!
SLOPODMODS
John&Sue,SLO,CA
kansasfrogs
Posted: 19 Jun 2017 at 6:31pm |
Thank you so much!
FROGGY
voisj
Posted: 19 Jun 2017 at 8:19pm |
Hutch, Finally did it, Thanks for the idea!!! All my wires came in from the top, so it was easier to move the radio up. I was able to just unscrew the mullion and move it up. You can see the holes where the radio used to be, still need to fill them and still need a door. Every cu in counts!
SLOPODMODS
John&Sue,SLO,CA
john in idaho
Posted: 19 Jun 2017 at 8:52pm |
If you want the gloss to (sort of )match , try some clear Deft. It is a brushing lacquer .
