shower walls bubbling, ripped caulking |
Post Reply | Page 12> |
clickscrazy
Senior Member Joined: 09 Aug 2017 Location: FL Online Status: Offline Posts: 106 |
Topic: shower walls bubbling, ripped caulking Posted: 19 Aug 2017 at 1:13pm |
What kind of screws did they use? I want to put some screws in the shower, but am not sure what to use.
2018 R-Pod 171
2014 VW Touareg TDI |
Javakid
Newbie Joined: 31 May 2017 Location: Rolla Online Status: Offline Posts: 8 |
Posted: 14 Jun 2017 at 10:04am |
shower was screwed down every few inches and resealed, no issues thus far
"Sometimes you have to pee in the sink."
Charles Bukowski |
Posted: 06 Jun 2017 at 8:37am |
Yes.. Remember, it's a house, that goes down the road. Stuff comes loose. Things need to be tightened, straitened, and maintained. Many owners don't seem able to grasp that. It sounds like you have found a good dealership.. That is better then finding a perfect Pod.. The Pod can be fixed. |
Javakid
Posted: 06 Jun 2017 at 8:15am |
Having realistic expectations is healthy.
Charles Bukowski |
Posted: 03 Jun 2017 at 4:21pm |
Good, should be easy fix. Commenting on post I have owned numerous campers over time, everything from a "land Yacht" Airstream I towed with a Chevy 3500 454, a Class C Motorhome w/tow behind vehicle, a real Teardrop and a Pod. Every one of them kept me busy fixing things. Like the old saying about boats (owned them too:)) A hole in the water you pour money into. All the systems and building materials, many things that can and do fail. Am not advocating being critical of taking delivery of a new unit and finding many issues and no resolve from a dealer. Just saying as long as you own an RV you will have a project.
Javakid
Posted: 03 Jun 2017 at 3:36pm |
Dealer tech is trimming, reseating and resealing the shower insert; they checked multiple new 2018 units, all have the same issue; insert too tall for the space-FR has been notified by written dealer notification.
Charles Bukowski |
Keith-N-Dar
Posted: 03 Jun 2017 at 10:27am |
You bought your pod without looking at it or researching capacities? |
Keith-N-Dar
lostagain
Posted: 03 Jun 2017 at 8:51am |
From the little experience I've had with travel trailers, none of them seem to be very well built. They necessarily use light and flimsy materials which always leads to things falling apart. But weight is their bane and if they used stronger stuff, the trailer would be much more costly and/or heavier. As for electrical and plumbing quality, there is no excuse for lousy workmanship except that they are pushing for fast assembly and that inherently leads to errors. I doubt any of the manufacturers pay very well, so pride of workmanship is also wanting.
The wiring quality reminds me of cars built in Detroit before the Japanese manufacturers started competing in the US. They get away with it because they all do it and no one seems to care. If a company followed a Japanese car model for electric components (and plumbing too), we'd probably see neatly tucked wiring harnesses and such instead of the rats' nests that are commonly found. But the wiring harnesses are costly to manufacture in a low volume environment, so they're no likely to use them because it will push up their price points. The aluminum frame is a good trend and much stronger than the old stick, glue and staple systems still found on many TT's. Now they need to figure out how to cheaply and efficiently build the cross framing in aluminum. Bottom line, TT's will always be a little flimsy and prone to breakage.
computerfixitguy
Groupie Joined: 04 Jun 2016 Location: Littleton, CO Online Status: Offline Posts: 91 |
Posted: 03 Jun 2017 at 12:39am |
Sorry you have had so many obstacles. Attention to detail is a concept lost on most trailers, including my little RPod. My neighbor has a 60,000 5th wheel and its trim falls off too. A little bit of glue would go a long way. However, on the bright side. I fit into every camping spot. Its really light weight. The community is very strong and I like that. The RPod is the lightest, nicest, and biggest trailer I could find. I love mine, even though it leaves a lot to be desired regarding fit and finish.
This weekend I am rebuilding my seats because the factory forgot some parts, but while I am in there, I am adding some USB ports. I would buy another. If I could tow more than 3500 lbs, I would buy something nicer, but it would cost 30K and be too heavy for my Jeep. Derek
Kim & Derek
2016.5 176t 2015 Jeep Rubicon JKU (trips west) 2008 Town and Country (trips east) 2 kids, 2 dogs |
Posted: 02 Jun 2017 at 10:20pm |
Sounds like you got the Friday afternoon 'Pod. My condolences. However, why do you think you can't both haul your gear and take water? The axle is not THAT weak. You do have to be selective in how much stuff you take. It is only a small space after all. Even with a full water tank, you should still have over 400 lbs of cargo capacity remaining. The really heavy stuff can go in your Tacoma. We did two trips across the US from NC to AZ and back plus trips up to NY and VT loaded and most of the time with a full tank of water (at least to start). We had no problems with the axle.
I agree that fit and finish leaves something to be desired. I had a bunch of issues myself. However, I just fixed the small stuff myself and did some modifications in the process. The TV is a peeve. Why put a 110V model in when a 12V model would have made much more sense? I bought a small inverter to power it as that cost less than buying a 12V TV. I think if you find Forest River products unacceptable, you would find much of the competition equally unacceptable. I did not want to pay $40,000 or more for a trailer. I did not expect an Airstream for the price I paid. |
