  New Posts New Posts RSS Feed: Refrigerator beeping Rpod 179
Topic ClosedRefrigerator beeping Rpod 179
Irish Tom View Drop Down
Direct Link To This Post Topic: Refrigerator beeping Rpod 179
    Posted: 17 Jul 2017 at 4:25pm
Had the same issue with my 178.  Condensation under the light cover.  Refrigerator thinks door is open, beep, beep, beep.  Yes have disconnected the light but you can try coating the contacts with bulb grease.
Irish Tom
2014 Ford Explorer Limited
wkendrvr View Drop Down
Direct Link To This Post Posted: 15 Jul 2017 at 7:48pm
It is probably the "door open beeper"  (this drove me NUTZ!)  If you look at your door switch, there is a small cable that goes into a circuit board and when the board gets "damp" from condensation, it causes the fridge to think the door is open.  I disconnected the cable, and no more beeping.  This will cause your Fridge light to not work, but that was a small price to pay to not have it go off in the middle of the night!
mcarter View Drop Down
Direct Link To This Post Posted: 15 Jul 2017 at 5:37pm
Just a heads up, there was warning indications. On the display.
TCMich View Drop Down
Direct Link To This Post Posted: 15 Jul 2017 at 5:32pm
Thank you.  We are running on AC
Direct Link To This Post Posted: 15 Jul 2017 at 5:28pm
The last time this happened to me - the GCI CB had kicked and I was using AC to power fridge.
Direct Link To This Post Posted: 15 Jul 2017 at 5:25pm
Rpod179. Refrigerator keep beeping every 2min for 15 seconds.  All systems running good, no flashing indicating lights.  Did this all night.  Any suggestions on how to fix this?
