Toilet valve lube |
Post Reply | Page 12> |
TEDDY
Groupie Joined: 22 Oct 2017 Location: Arkansas Online Status: Offline Posts: 94 |
Topic: Toilet valve lube Posted: 28 Oct 2017 at 11:05pm |
You might try the spray product recommended for the slide-out seals ..."Slide Out Rubber Seal.
Teddy
ToolmanJohn
Posted: 18 Aug 2017 at 6:54pm |
Just a splash of RV anti-freeze when storing between trips. I never had problems with the seal actually drying out, so I would probably try the right seal lubricant first so as not to damage it.
How hard is it to replace?
fwunder
Posted: 17 Aug 2017 at 8:35pm |
Small valve leaks are just part of the normal aging process. Just something those around you need to live with...
As far as the toilet goes, a cup or two of water is all you need. If you do keep it in storage for an extended period of time, I would probably put a layer of plastic (Saran Wrap) on top of water as well as all the sink and shower drains trying keep traps from drying out. Maybe some antifreeze if in cold climes. fred
Posted: 17 Aug 2017 at 6:53pm |
+1 to Jato, I have had water evaporate in toilet. But when covered in antifreeze it stays at level through the winter. If you have standing water in a container in your hose it will evaporate.
Bugout
Senior Member Joined: 01 Jan 2017 Location: S caroline Online Status: Offline Posts: 117 |
Posted: 17 Aug 2017 at 6:33pm |
How about a tucks pad and a dab of prep H . Sorry couldn't help myself
Jk Aiken South Carolina 2016 178 Toyota Tundra 2017 4.6
Posted: 17 Aug 2017 at 3:42pm |
Good one Mark ! We also keep a thin layer of water on our valve throughout the year except when we winterize, then we put a few ounces of rv antifreeze over the valve. Going on year 7 doing this, no issues. |
Posted: 17 Aug 2017 at 3:18pm |
So does Crisco.. and it does.. wait for it.... Double Duty... Buahahaha... |
Subzilla
Senior Member Joined: 23 Jan 2017 Location: Concord, NC Online Status: Offline Posts: 302 |
Posted: 17 Aug 2017 at 2:15pm |
I've read to NOT put petro products on the seal as it will swell up and cause additional problems. Camco and Thetford make a product just for this problem.
Mark
Concord, NC 2017 RP 179 "Podzilla" 2011 Silverado 1500 4X4 |
GLBCamper
Senior Member Joined: 30 Jun 2015 Location: Oregon Online Status: Offline Posts: 274 |
Posted: 17 Aug 2017 at 2:09pm |
I had the same concern, no matter what you put in it! I do keep a small amount of water in the bowl to keep the seal from drying out. I have also seen suggestions to put a thin coating of vaseline on the rubber gasket but I wonder if a petroleum product might actually break down the rubber.
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab New: 2016 EVO ATS 200rd 2016 F150 4x4 Sport |
Keith-N-Dar
Posted: 17 Aug 2017 at 11:52am |
+1 |
Keith-N-Dar
