wthoms2000
Topic: Positive ground? Posted: 10 Nov 2017 at 6:25am |
Positive is positve, and negative is negative, ask Nikola Tesla. A $15 VOM (volt ohm meter) would confirm the negative cable is actually connected to ground using the continuity beeping setting. The VOM set to 12V would also confirm the pos and neg polarity on the battery, regardless of the markings.
2 cents from robotics engineer.
Enjoy!
Porta Poddy
Wil and Luz, Orange County, CA
2017.5 179 HRE
2021 Ranger XLT FX4
REDARC Brake Controller
Tars Tarkas
Posted: 27 Aug 2017 at 10:29am |
Originally posted by GlueGuy
The battery isn't reverse polarity, they just built the posts on the opposite sides from "regular", whatever that is. If you go through all the batteries on the store shelf, some will have + on the right, some will have the + on the left.
I don't think there is any right or wrong here; it's sort of like some cars having the gas fill door on the left side, some have it on the right.
I would say it's kind of odd that someone chose to switch the polarity of the battery on an existing installation. It might be that they were out in some out of the way place, and had to use whatever someone happened to have on the shelf. |
My guess is that the original issue in this thread was that someone threw on a screwed up battery just before they sold their pod. They had a battery on which the polarity had been reversed by accident or negligence, but they hooked it so it would work. That is they ran the "positive" terminal to the ground, and negative to the load, which would let it work for a while. It would be a pretty crappy thing to do, and possibly dangerous. That's one issue. The other thing is that no one sells new reverse polarity batteries. That would mean the post labeled + was - and the post marked - was +. Reversing the position of the posts, so the positions of the + & - posts are reversed is fine. That makes perfect sense. But that's not a reversed polarity battery, it a battery with the posts reversed. Apples and oranges. I'd say no one chose to reverse the polarity on the battery. From my very limited understanding, this is a freak thing that can happen. You might be able to encourage it by completely depleting a battery and then hooking it up a charger backwards, but I'm not sure that doing that is guaranteed to cause the polarity to change. Whether such an exercise works or not the battery is pretty much toast. Why would anyone do that on purpose? TT
FJ Cruiser
GlueGuy
Posted: 27 Aug 2017 at 10:00am |
spydie
Posted: 27 Aug 2017 at 9:24am |
actually if the + post is really negative and the "-" post is positive, I'd say it's really reversed polarity.
2018 R-pod 176
2017 RAM 1500 5.7L Hemi
Tars Tarkas
Posted: 27 Aug 2017 at 2:26am |
So the post are reversed, not the polarity. That makes sense, although different cables would be easy and maybe cheaper.
TT
FJ Cruiser
GlueGuy
Posted: 27 Aug 2017 at 1:33am |
I used to have an old John Deere tractor that had a positive ground. You just had to connect the positive cable to the block and the negative cable wherever it was supposed to go (voltage regulator?). You didn't need some kind of special reverse polarity battery.
TT
It's just where they ran the wires. On our tractor the wires won't reach if I use a "normal" polarity battery. So I use the -R equivalent.
Tars Tarkas
Posted: 26 Aug 2017 at 6:18pm |
I get the idea of the polarity of a normal battery being reversed. As Mike said, it's very rare and pretty much requires someone not paying attention. The positive terminal becomes negative and the negative terminal becomes positive. I don't understand how in the world anyone could even make a reverse polarity battery for sale though. Unless that means having the + on the right front instead of the left front so the cables will reach the appropriate terminal. (Why not just turn the battery around?) On these alleged reverse polarity batteried the positive terminal is positive and the negative terminal is negative. Right?
TT
FJ Cruiser
Tars Tarkas
Posted: 26 Aug 2017 at 6:17pm |
I get the idea of the polarity of a normal battery being reversed. As Mike said, it's very rare and pretty much requires someone isn't paying attention. The positive terminal becomes negative and the negative terminal becomes positive. I don't understand how in the world anyone could even make a reverse polarity battery for sale though. Unless that means having the + on the right front instead of the left front so the cables will reach the appropriate terminal. (Why not just turn the battery around?) On these alleged reverse polarity batteried the positive terminal is positive and the negative terminal is negative. Right?
TT
FJ Cruiser
GlueGuy
Posted: 26 Aug 2017 at 1:21pm |
Originally posted by furpod
But also, having been to the Pod birthing grounds a few times.. I know that "Bob" uses "what is at hand" for a lot of things.. LOL So seeing a different or odd color wouldn't surprise me much.
Bob must have known "Tony" who did a large percentage of our current abode in the DIY tradition. It was amazing that most of it worked. But along the way, a lot of surprises were encountered. After living here for 21+ years, I think I have cleaned out almost all of the surprises. None-the-less I am very, very cautious whenever I open up something that I haven't looked inside before.
Posted: 26 Aug 2017 at 12:11pm |
I will bow to your "older guy" wisdom, having only been retired 20 years, I am still a youngster.. But, anyways.. having worked on a BUNCH of pods over the years, and a couple Airstreams, and now a Lance, they were all wired Black and White from the batteries. Maybe because on a TT you have both 120v and 12v, so they follow the 120v convention, I don't know.. but I fully agree that a DVM is a MUST have...
