  New Posts New Posts RSS Feed: Broken Fan Casing
Topic ClosedBroken Fan Casing
NWRPodder View Drop Down
Direct Link To This Post Topic: Broken Fan Casing
    Posted: 09 Oct 2017 at 1:13pm
Thank you for the feedback on this issue. Apologies for the late replies. I did get confirmation this solely cosmetic and doesn't impact water leaking through the top.
Can I assume that replacing this is as easy as unscrewing the pieces and putting a new trim piece in? Or does it require actually removing more than that? I would check myself except we don't store the pod at home so I don't have quick access.
Thanks again in advance for any help here.
2016 R178
2007 Ford Expedition V8 5.4L
mcarter View Drop Down
Direct Link To This Post Posted: 05 Sep 2017 at 7:26am
I have an all-weather cover on mine from CAMCO, I believe. I can leave vent open and it is not affected by wind or rain.
Direct Link To This Post Posted: 04 Sep 2017 at 7:19pm
Call Fantastic Breeze. Their customer service is top notch. And no, you shouldn't have any moisture issues because of that.
Direct Link To This Post Posted: 04 Sep 2017 at 7:12pm
Hi folks.
I had my first wind incident. At least I believe that is what happened as I am not sure what else would have caused it. Before we started our last trip the inside of the vent fan looked fine. Near the end I looked up and realized I have two cracks on the inside of the casing. See photos. We had some really strong wind gusts and for the first few hours I left the vent cover pretty open plus it was in the direction for the wind to push up under it, not over it. Ouch
Anyway, I will eventually look to get it fixed and I assume it's only cosmetic and not an issue if I left it this way as far as potential moisture or rain water coming in though it. Is that a correct assumption regarding water coming in?
If you are reading this and haven't had this issue yet take this as a reminder to batten down the hatches as soon as the wind goes anything past light breezes. Smile
2016 R178
