  New Posts New Posts RSS Feed: Air and heater
Topic ClosedAir and heater
maddogmiller View Drop Down
Direct Link To This Post Topic: Air and heater
    Posted: 26 Sep 2017 at 1:25pm
I have the same issue with my 2017 RP-178. (My thermostat is different than the picture shown.) I found it easiest to simply flip the circuit breaker for the A/C if I only want to use the heater. The heater and thermostat run off of 12-volt and the circuit breaker stops the 120-volt to the A/C (and the noisy fan!)
TheBum View Drop Down
Direct Link To This Post Posted: 15 Sep 2017 at 2:27pm
There should be a step 4 that says to press the mode button again until you get to Furnace.
marcagoddard View Drop Down
Direct Link To This Post Posted: 15 Sep 2017 at 1:20pm
Thank you so much! I will give it a try.  But in step 3 if i go to off, how will the heater come on without being in Furnace  mode?
Marc Goddard
Direct Link To This Post Posted: 15 Sep 2017 at 10:05am
There is a period of a few seconds in step 3 when the ON/OFF LED stays on, but it will go out.
Direct Link To This Post Posted: 14 Sep 2017 at 7:10pm
Ditto!!
Direct Link To This Post Posted: 14 Sep 2017 at 6:32pm
set your thermostat to auto instead of low or high that it's on now.
Direct Link To This Post Posted: 14 Sep 2017 at 5:17pm
I just bought a 2015 RPOD 177.  Everything is working great but when i have the trailer plugged into 110 and i adjust the thermostat to FURNACE the heat does come on but so does the air conditioner.  Any idea why the cold air also comes on?  The solution is to unplug it , but i can't figure out why the4 air comes on with the heater.  Any thoughts??
Marc Goddard
