screen that goes along the bottom of the camper |
itspossible
Newbie Joined: 08 Aug 2017 Online Status: Offline Posts: 14 |
Topic: screen that goes along the bottom of the camper Posted: 25 Sep 2017 at 4:53pm |
I bent the kedder channel out a little bit and that allowed the screen to exit and bend up and over the tire fender, also flared the channel to allow it to re-enter on the other side of the tire...works great.
Never far enough
marwayne
Posted: 24 Sep 2017 at 9:01pm |
Leo B
podders Helping podders - pHp Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4517 |
Posted: 24 Sep 2017 at 5:06pm |
That's even to cold for Ice Fishing
fwunder
Posted: 24 Sep 2017 at 4:45pm |
Not sure both my Buddy heaters could keep up with minus 40 under the dome! But, I guess that stuff stays pretty flexible in cold. What is it? Thanks. fred
marwayne
Posted: 24 Sep 2017 at 4:40pm |
For what it's worth, this material is good to minus 40* C
fwunder
Posted: 24 Sep 2017 at 4:35pm |
Very nice!! No surprise from you!
I did something similar cutting up a polyethylene tarp, some 3/8" cheap keder rope and duct tape. Doesn't look nearly as good as yours, but keeping the wind out is huge! Nice work...as usual. fred
Leo B
Posted: 24 Sep 2017 at 4:16pm |
Nice work!!
marwayne
Posted: 24 Sep 2017 at 3:38pm |
I put solid material in the keeder to keep bugs and wind out and keep heat in. I also put a light over the step.
mjlrpod
Senior Member Joined: 27 Sep 2016 Location: Massachusetts Online Status: Offline Posts: 1215 |
Posted: 24 Sep 2017 at 1:56pm |
I dont know the official answer. I cut my lower screen into 3 sections. The front section goes from the front of the pod, till it hits the fender. On this section i cut out to fit over the step. I then took and went from the back of the pod, till it went under the fender, and reached the axle. i then cut the excess sticking out the back. That gave me a 3rd piece that i dont put into the track, i place it behind the tire, i cut a slit to allow it to go down around the axle on both sides, and use clips to connect the front and rear sections. This creates a long " continuous " screen
2017.5 Rp-172
tdrace
Senior Member Joined: 18 Apr 2010 Location: Florida Online Status: Offline Posts: 133 |
Posted: 23 Sep 2017 at 5:13pm |
How do you get this past the tire? Do I need to modify it?
tdrace's
2018 180 2010 FORD F150 V-8 equalizer e-2 hitch Sisters on the Fly #1569 |
