Dometic refrigerator equivalents |
JandL
Senior Member Joined: 29 Mar 2014 Location: California Online Status: Offline Posts: 364 |
Topic: Dometic refrigerator equivalents Posted: 01 Oct 2017 at 9:49am |
JandL
Danielw1
Senior Member Joined: 01 Apr 2017 Location: Oregon Online Status: Offline Posts: 115 |
Posted: 01 Oct 2017 at 9:41am |
Did you replace the main regulator or is there a separate one for the fridge? |
JandL
Posted: 29 Sep 2017 at 4:00pm |
If your refigerator is working on AC that means when running on propane the flame is not big enough for the absorption process to work correctly. Cleaning the burner assembly and replacing the propane regulator made all the difference in my pod
JandL
lostagain
Posted: 29 Sep 2017 at 3:27pm |
Indeed. I just did that with the fridge space, the water heater area (inside included), and the heater. Blowing out and vacuuming debris, including original manufacturing debris, reduces the chances of things getting crud stuck in them and ceasing to work. It also helps to reduce the risk of little visitors taking up residence in unwanted places.
Our pod
Groupie Joined: 03 Oct 2016 Location: Olympia WA Online Status: Offline Posts: 62 |
Posted: 29 Sep 2017 at 2:17pm |
Almost all of an R-Pod's spaces can benefit from cleaning with compressed air. Dirt accumulates and leads to failure.
Life is good.
lostagain
Posted: 29 Sep 2017 at 1:16pm |
I really meant to say 3.7 cu. ft. 37 cu. ft. is about the whole volume of our Pod.
lostagain
Posted: 29 Sep 2017 at 11:45am |
We replaced our Dometic with a Norcold N3103AGR 37 cu.ft. fridge, but it works on the same basic technology so, unless Norcold knows something Dometic doesn't, it's subject to the same issues. So far it's working well. Stays nice and cold on LP even on hot days with temp's as high as 101. It comes with only one pancake fan on the back, so I salvaged the pancake fans off the Dometic and mounted them near the upper vent to improve air circulation. I never connected the DC because there is really not much point in doing it. If no AC is available, we run on LP, including on the highway.
GlueGuy
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2654 |
Posted: 29 Sep 2017 at 8:40am |
The primary issue is that you will have to decide between an absorption mode refrigerator or a compressor mode refrigerator. If you boondock a lot, then an absorption mode may still be your best choice, because it can run on propane. A well insulated compression mode refrigerator is still going to use "around" 700 watt-hours per day.
You should read this article before you decide: http://www.truckcamperadventure.com/2016/02/the-danfoss-compessor-refrigerator-pros-cons-and-a-few-tips/
Happy Tripping
Posted: 29 Sep 2017 at 7:53am |
Hello.
Like many of us, after 3 years our refer is not warming well on propane, AC works fine. I will use previous 'step by step' forum messages to clean unit, altho to me it's a daunting task. My questions are - 1. Is there a more reliable, robust technology out there in refer land that isn't so touchy, but doesn't cost two arms and a leg?? I am afraid that IF I am successful, it will only happen again. 2. While the propane nozzle is disassembled, does the Dometic refer still work on electricity?? Thanks to all |
