Solar power for fridge - Event Date: 28 Oct 2017 |
CharlieM
Calendar Event: Solar power for fridge Posted: 07 Nov 2017 at 9:53am |
The ampacity of 12 AWg is not really the issue. Ampacity is a fire safety rating based on the allowable temperature rise at a given current. Voltage drop is the real issue for us. One half to one volt drop at 120V has little effect but it has a huge effect on a 12V charging system. The TV's charging system limits the alternator output to ~13.5V as measured at the TV battery. By the time this suffers the drop in the long #12 wire it delivers very little current to the TT battery and appliances. Most TVs only deliver 10A max to the TT and much less most of the time. |
lostagain
Posted: 07 Nov 2017 at 8:57am |
Margaritas with ice crushed by hand requires no electro/mechanical equipment whatsoever. Just smash the ice inside a towel with a crescent wrench, or what ever blunt objet is handy, put the ingredients in a mason jar, shake, and serve.
For those who are purists, use a good tequila, lime juice, triple sec or Contreau [depending on your budget], and salt along with your manually crushed ice. --- no margarita mix stuff. Yuck!
sailor323
Senior Member Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
Posted: 07 Nov 2017 at 7:49am |
but I just use a 12v blender |
Keith-N-Dar
Posted: 29 Oct 2017 at 1:20pm |
And I was feeling pretty smug for adding a solar battery maintainer to our Pod.
Keith-N-Dar
Leo B
podders Helping podders - pHp Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4517 |
Posted: 29 Oct 2017 at 1:15pm |
Ha! A must for every camping trip!
fwunder
Posted: 29 Oct 2017 at 12:48pm |
I agree with the above comments. Solar powered fridge just doesn't make a lot of sense. Propane is the way to go. However...
An earlier discussion involved gallons of Vodka. I therefore, do recommend a solar powered blender! Strawberry Daiquiris for everyone! |
Posted: 29 Oct 2017 at 12:05pm |
Just run on propane. It will run for 5-6 weeks on a single 20 pound tank. The battery bank and solar panel requirements for "running on solar"just can't be done on a 17 foot trailer with 8 sq feet of flat roof.. and will cost 1/2 as much as the Pod did.
GlueGuy
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2654 |
Posted: 29 Oct 2017 at 10:34am |
JandL
Senior Member Joined: 29 Mar 2014 Location: California Online Status: Offline Posts: 364 |
Posted: 29 Oct 2017 at 10:21am |
Refrigerator on DC draws around 11.00 amps. It would take many solar panels to power the refrigerator. I would recommend running it on propane if you don't have AC available. I can't run my refrigerator on DC while driving because the wire from the truck battery to the RV socket is only 12 gauge. The truck alternator can not supply the needs of the truck and refrigerator at the same time, so I run on propane
JandL
js555
Newbie Joined: 04 Jan 2017 Location: ca Online Status: Offline Posts: 10 |
Posted: 29 Oct 2017 at 1:44am |
Hi all,
I bought a 178 last december and I am so happy. I want to run the fridge with solar, I am not familiar with any of these things. I could not run the fridge on battery the other day as I was on a 7 hour trip. Any ideas or reasons why ? But I would love to save battery and run the fridge, but it seems that the fridge will not run on battery mode. Is there a reason for this ? So what wattage and amperage would I need to run the fridge and the TV ? How many batteries would I need and would I need an inverter to make it 120 V's ? Any help would be appreciated. Best JS• |
