Fastway E2 and WDH setup |
Post Reply | Page 123> |
Grandpa Hiker
Senior Member Joined: 04 Jan 2015 Location: Martinsville, V Online Status: Offline Posts: 143 |
Topic: Fastway E2 and WDH setup Posted: 11 Apr 2018 at 5:08pm |
This is also a very good way of making 100% sure that your hitch is securely attached to the ball!!
Rob & Becky
2014 Ford Explorer 3.5 SOHC V6 2015 R-179 Pod aka Piddle Pod "Life is not about waiting for the storms to pass, it is about learning to dance in the rain!!" |
texman
Senior Member Joined: 24 Jul 2014 Location: TeXas Online Status: Offline Posts: 446 |
Posted: 11 Apr 2018 at 10:31am |
ditto to zilla's comments. I don't want a flying pod coming loose when all that is jacked up. But in reality, the tow vehicle falls and is fine and the pod might bounce a bit and scare the tar out of you. I think that was my main concern, the stress in the pod hitch and if that is a problem. The wdh and ball is really beefed up so the pod hitch is carrying the weight of the rear of the tow vehicle at the point of attach and detachment.
Subzilla
Senior Member Joined: 23 Jan 2017 Location: Concord, NC Online Status: Offline Posts: 302 |
Posted: 11 Apr 2018 at 10:27am |
It's not so much the jack I'm worried about but the little latch on the Pod hitch holding up the tongue weight and the truck end weight. I know it's the accepted way to do it. Just wondering if it could weaken it over time.
Mark
Concord, NC 2017 RP 179 "Podzilla" 2011 Silverado 1500 4X4 |
Larry-D
Senior Member Joined: 12 Oct 2017 Location: Middle TN Online Status: Offline Posts: 109 |
Posted: 11 Apr 2018 at 10:17am |
That is the way I was taught at the dealer for our 28' TT. Hook up the trailer, lift the truck's rear end and trailer's front end using the tongue jack, put in the WDH bars, lower everything and go. Do the reverse to unhook. I know it sounds like the jack is struggling to do that but it'll do it. When hooking up the 28' TT i'm lifting it and the back end of a RAM 3500 dually. Keep in mind you're not lifting the whole weight of the trailer, only the tongue weight plus the back end weight of the tow vehicle.
Subzilla
Posted: 11 Apr 2018 at 10:15am |
I had thought about using my bottle jack to lift up the truck by the receiver hitch....
Mark
GlueGuy
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2654 |
Posted: 11 Apr 2018 at 10:14am |
Subzilla
Posted: 11 Apr 2018 at 9:59am |
I also use the jack with my Equalizer WDH to remove the friction bars. Anybody have any fear of overstressing the hitch latch on the trailer by lifting both the trailer and the truck? Doesn't seem like a whole lot there....designed more to keep the trailer from bouncing off. Me overthinking things?
Mark
texman
Posted: 11 Apr 2018 at 8:25am |
my drive way is sloped and i had a situation where pod was level but tow vehicle tilted to left(driver). That is tricky. Right side (passenger)was easy to remove with jack height. The left(lower side) had a lot of tension to relieve due to the tow vehicle tilt. Finally got it loose but learned to undo the trunnion bars on level ground or at least when pod and tow vehicle are at the same angle. With an electric jack failure, worst case, i will have to use the little manual crank to raise the jack to remove bars. I hope that never happens.
Posted: 10 Apr 2018 at 5:54pm |
Perhaps you haven't. I have. It is good to have an option. I would never pop the bar off without raising the jack. Even so, the Equal-i-zer hitch will not let the bar swing freely due to the friction at the hitch head. |
Larry-D
Posted: 10 Apr 2018 at 4:44pm |
X2 on raising the TT to take the tension off the bars. So much easier and safer, well worth the couple of minutes.
