Adding exterior lighting |
pearlhiggy ![]() Newbie ![]() ![]() Joined: 25 Apr 2022 Location: Brockport, NY Online Status: Offline Posts: 18 |
![]() ![]() ![]() ![]() Posted: 05 May 2022 at 11:00am |
oh that would be great... I will check it out. Like a porch light!!!
Thank you.
The Higgins' Girls,
Pearl, Zoey Marie & Riley Ann 2017 Rpod 179 |
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2634 |
The outdoor light on our 179 is just above the door. Perhaps your is just burned out?
There is a light switch next to the one for the bathroom, but not sure what the switch goes to. But no lights come on.
The Higgins' Girls,
As far as I can see, I do not have lights on the outside of my camper. So while it is parked in the driveway. So at night if I want to go out to the camper, it is very dark. I tried adding a solar, keeps falling off.
The Higgins' Girls,
voisj ![]() Senior Member ![]() Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
rawest,
I added an RGB LED light strip under upper C channel and also under the lower C channel. They are dim able and can be any color. The switches are in the rear storage compartment. Got them on Ebay for $7 each, Get the waterproof type. ![]() also have this landscape light I use, it's metal and plugs into the Zamp port and sticks to the magnet for the storage door. $11 at home depot & I used an extra zamp style plug that came with my battery charger. ![]() While i was at it I put one in the storage compartment. ![]() |
Larry-D ![]() Senior Member ![]() Joined: 12 Oct 2017 Location: Middle TN Online Status: Offline Posts: 109 |
I added a marine grade 2-LED light under the step. It is wired to a magnetic switch on the screen door and a "master" switch. The "master" switch has to be on and the LEDs light up only when the screen door opens.
rawest50 ![]() Senior Member ![]() ![]() Joined: 07 Mar 2017 Location: Arkansas Online Status: Offline Posts: 440 |
Have you added any? I have a couple of solar light but I have to remove them. Anything simple? Just looking.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler 2017 Chevy Colorado Z71 Off Road Crew Cab 2 Weiner dogs Great wife puts up with my BS ❤️ Thoroughbred Racing. ![]() |
