Tom A
Topic: Newbie questions Posted: 06 May 2018 at 8:38pm |
Originally posted by Ben Herman
Originally posted by Leo B
You're correct on that switch in the water heater compartment. You just need to make sure there is water in the tank when you use the WH connected to shore power or it will blow the heater element inside the tank. |
Another newbie here with a follow-up question - do you have to flip the switch each time you go between shore and lp for the water heater? If so, I definitely want to move the switch. Getting under the bed each time seems like a real pain in the butt |
The second switch on the water heater itself is not under the bed on my Rp-190. I access the water heater outside with a flip down door. That second switch is out there.
2018 Sequoia--2018 RP 190
Posted: 06 May 2018 at 7:12pm |
If you normally dry camp, just leave the switch off in the water heater compartment and turn the rocker inside the camper for the LP heater in the on position. Reverse that if you normally camp using 110 shore power. It doesn't hurt anything (as long as you have water in the HW tank) if you leave the switch in the water heater compartment "on" even though you are dry camping and using propane to heat your water. If using 110 shore power you can shorten the time it takes to recharge the hot water by having both switches in the on position.
Ben Herman
Posted: 06 May 2018 at 7:05pm |
Leo B
Posted: 06 May 2018 at 6:29pm |
Tom A
Posted: 06 May 2018 at 5:56pm |
As far as the water heater is concerned, I did use the On/Off switch on the bathroom wall. When nothing happened I looked in the tank compartment and found another, unlabeled rocker switch down in the corner and flipped that-- got hot water right away and I assume that was from shore line electric power.
Thanks folks.
Ben Herman
Posted: 06 May 2018 at 5:54pm |
I use sheetrock wall anchors, the ones that look like this:
When using these in sheetrock, you just hammer them in to start them. However the Rpod wall is a thin plywood veneer over foam, so I predrill a small (like 1/4") hole before carefully driving these in with a screwdriver. Suggest just using a hand screwdriver, not power - it'd be too easy to drive these in too deep. Also be careful not to drill the hole deeper than 1 inch. Others on the forum have previously mentioned drilling too deep, and going through the wall. |
Thanks, I have used those anchors successfully in sheetrock walls, that's a good idea. But, are you talking about exterior walls?
I still don't know how thick the inner partition walls are (bathroom). |
yes, exterior walls. Not sure how thick the interior walls are (and cannot get out to TT right now) but should be fairly easy to tell by looking at the bathroom door area. Try a search on this forum, I would imagine something'll come up...
Tom A
Posted: 06 May 2018 at 5:51pm |
Ben Herman
Posted: 06 May 2018 at 5:00pm |
voisj
Posted: 06 May 2018 at 4:55pm |
SLOPODMODS
John&Sue,SLO,CA
Posted: 06 May 2018 at 4:12pm |
Tom A,
The interweb is the best source of info on how to use your water heater on propane., recommend you start compiling an info book and copy print the various systems and how they work and how to operate. I have a 3" binder of info I keep with Pod. You will need it as issues arise.
Pods don't have studs per say, they have aluminum framing, mostly around windows and door. You can use dew lines but hard to extrapolate from outside to inside. Best to buy a good stud finder that will locate metal and electrical. I have used a very small drill bit if in doubt, one I could easily hide any wall damage. Granted tee dew lines are very prevalent on outside walls.
Lastly - I wouldn't use anything over 1" on the walls - anywhere.
