RVQ mount with quick connect to propane on tongue |
JerryCk
Newbie Joined: 10 Oct 2018 Location: Montana Online Status: Offline Posts: 13 |
Topic: RVQ mount with quick connect to propane on tongue Posted: 30 Oct 2018 at 6:08pm |
I took some more pictures to provide more detail. You may notice that we had a little snow overnight. |
JerryCk
Posted: 30 Oct 2018 at 8:55am |
The RVQ and its carrier ride on the J rail by gravity. They would have to be secured with a strap. It only takes a minute to set everything up. I stow the carrier and RVQ in the rear cargo area (they fit thru the hatch). I tuck the gas umbilical behind the batteries.
Leo B
podders Helping podders - pHp Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4517 |
Posted: 30 Oct 2018 at 5:56am |
Ditto!
Posted: 30 Oct 2018 at 3:58am |
Looks great! When you're towing the work table gets stowed obviously. Do you need to stow the RVQ as well or can it stay in place?
JerryCk
Posted: 29 Oct 2018 at 11:15pm |
After losing my Aliner to a falling tree I was able to salvage the J rail and carrier frame for my RVQ, plus the hose and quick connect for the propane. The easiest place to set these up on the Rpod appeared to be off the wishbone of the tongue. In my scrap pile, I had a set of tracks and mounts for an overhead door so I used them to make a frame to permanently mount the J rail. The uprights are the uncut top angles and the backsides are cut pieces of rail, clamped on the wishbone with 5/16” carriage bolts. The white J rail is bolted to the uprights with ¼” machine bolts whose heads have been ground slightly to fit into the J rail channel. The gas supply to the trailer cabin runs from the regulator thru a hose to a ½” male flare bulkhead fitting behind the batteries. I ordered these two fittings to insert a 1/2x1/2x3/8 inch reducing tee into the cabin supply line at the bulkhead: SupplyHouse.com, 130 Spagnoli Rd, Melville, NY 11747; F40-039 (44-886) 1/2" x 3/8" Brass Reducing Flare Tee $4.75; F40-096 (70-8) 1/2" Brass Female Flare Swivel $4.55; Shipping and Handling $4.95; Total $14.25 The supply line to the RVQ runs from the tee to the quick connect at the RVQ. I had some laminate counter material, so I made a work surface that mounts alongside the RVQ. It has a 2-¼” hole that slips over the top of the hitch jack, and a diagonal brace running from the wishbone up to a block under the work surface. Everything is held in place by gravity! |
