GlueGuy
Topic: Cable tv hookup Posted: 11 Mar 2019 at 10:31am |
Originally posted by AL1010
Wow, I’m even having a hard time understanding what I wrote. |
I have that problem too. For me it's usually best to drink my coffee before I write.
AL1010
Posted: 10 Mar 2019 at 9:58pm |
AL1010
Posted: 10 Mar 2019 at 9:56pm |
Did you read my 1st post from today?
AL1010
Posted: 10 Mar 2019 at 9:54pm |
1st thing I checked , but sat wire goes to wall connection and cable wire goes to booster curcuit board.I pulled the booster outlet. I would try to explain everything thing but it might get more confusing. They may have the booster board wired wrong, but the booster works. I’ll need to find out what cable go where on the circuit board for the booster. There’s 4 coax cables behind the wall outlet. RED is SAT, Black feeds to entrance area TV. Grey and White one goes the cable connector on outside and other goes to antenna.
Richand Cindy
Posted: 10 Mar 2019 at 8:16pm |
It is a common mistake that the sat and cable wires are switched. So if you follow the instructions people have posted here and still not getting any cable channels you need to connect the cable coming in from the campground to the satellite connection and most times it fixes it.
AL1010
Posted: 10 Mar 2019 at 5:09pm |
Good possibility.
mjlrpod
Posted: 10 Mar 2019 at 4:20pm |
If it worked on Sat hook up, maybe it's wired wrong? Maybe mislabeled? Glad it atleast worked eventually.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
AL1010
Posted: 10 Mar 2019 at 2:47pm |
Basically what I found , it wouldn’t program with the antenna booster inline , on or off.
AL1010
Posted: 10 Mar 2019 at 2:44pm |
I was assuming everyone knew that, sorry. Antenna booster TURNED OFF and Digital Cable would not program.
mjlrpod
Posted: 10 Mar 2019 at 1:25pm |
I might be misunderstanding, but it's been stated that you should not use the antenna booster when watching cable. Maybe you meant something else.
2017.5 Rp-172
2020 R-pod 195
I'll be rpodding
