Page 123 8> |
David and Danette ![]() podders Helping podders - pHp ![]() ![]() Joined: 24 Nov 2009 Online Status: Offline Posts: 1216 |
![]() Posted: 27 Mar 2019 at 3:11pm |
As far as being related to the original r-pod I see the 195 as a distant cousin. I was right in the beginning thinking it may not have a fiberglass roof but at least it has a torsion axle.
I got an email from Scott Rhode at FR that clarifies the roof material. It is not fiberglass, tpo, or edpm. Instead, it is XTRM Ply PVC roofing which is also used on the Surveyor line. It is more durable than tpo or edpm (fiberglass is not mentioned in the flyer he attached describing it). It never needs treatments. It has a Solar Reflective Index of 109. It sounds like it will be a good roof material as the manufacturer has a 15 year warranty on it. The front and back still look to be fiberglass. However, until we see close-up pictures or see one in person, it will be hard to tell for sure where the fiberglass transitions to the PVC in front and back and how it is sealed on the edges.
lostagain ![]() Senior Member ![]() ![]() Joined: 06 Sep 2016 Location: Quaker Hill, CT Online Status: Offline Posts: 2588 |
I gotta say the 195 looks like a really nice trailer and it's still short enough to fit into many mountain campgrounds with limited trailer space. If I had a bigger bank account, I'd consider buying one, but I don't, so I won't. It looks like, once it's filled with all the normal stuff that people will carry, it'll weigh out at about just a little under 5K, which is a little on the heavy side for some SUV's.
Unless FR switched axle vendors 6 lug means it’s the Lippert 5200 lb axle family. They’re derating the axle to 4400, probably to keep the gross wt under 5000. So that’s good for reliability.
The other thing in that video is it confirms the fresh tank is forward. So, we’re gojng to be looking at a 600 lb tongue weight or more if the tank is filled and the normal boondocking battery and propane tank mods are added. Not a safe 5000 lb towable trailer in by opinion. |
Woodmiester, not to worry, there will be r-pods around for many years to come in the used travel trailer market. Our 172 from way, way back in 2009 has many years of life left in it yet and when we are done with our travel trailer days, we will probably have no difficulty finding a happy buyer.
Yesterday, one of our clients asked us to make a replacement cushion for a 1996 Aljo 18' double axle travel trailer. Except for the very low ceiling [I bumped my head on the ac] it had more features than the r-Pod, including a full stove and oven, a separate shower and sink in the head, a double bed/couch, and a dinette area. With a little work, they had taken this old classic and made it almost like new. There is a market for r-Pod like trailers and if FR doesn't want that market segment any more, then some other company will fulfill the demand. Every product goes through a life cycle and eventually dies out, but where there is a continuing demand for the original concept, some clever company will jump in and grab the opportunity.
There will likely be a demand for the smaller R-Pods as well as the 195. If we did not already have our 179, I would be looking hard at the 195 as the older we get, the harder it is to do the crawl-over. It still maintains a lot of the features of the R-Pod line even if it is not quite what is expected. Improvements mentioned in the videos beyond what is already discussed: Fully enclosed bottom meaning it will be better in cold weather. No mention of tank heat, so it still is likely not built for 4-season use, but add the hot water recirculation modification some have done and that would solve that, at least for the fresh water system.
Woodmiester ![]() Senior Member ![]() ![]() Joined: 03 Aug 2018 Location: Greenwood IN Online Status: Offline Posts: 142 |
Time to say goodbye to the R Pod as we know it!
As usual, they have taken a great idea and gradually ruined the whole concept of a (truly) light weight ,aero dynamic, self contained unit and moved it into the realm of boring piano box trailer (Not camper). It will be unusual to see a true R POD on the road in a few years..............Whatever the market calls for I guess. I hope to have our POD for many years to come.
Swampfox
Okay, I see on the video that the wheels are 6 lug. Whether that indicates a beefier axle or just an upgrade to 15" wheels is unclear.
Subzilla ![]() Senior Member ![]() ![]() Joined: 23 Jan 2017 Location: Concord, NC Online Status: Offline Posts: 302 |
Mark
Concord, NC 2017 RP 179 "Podzilla" 2011 Silverado 1500 4X4 |
The axle situation on these trailers is all a bit of a puzzle.
Last summer when I asked Lippert if the had a heavier axle they could sell me the first tech sales guy said he could sell me a 4400 lb axle (could have been 4200 lbs, can't recall exactly) but it was identical in all respects to the part number I gave him for the 3500lb one I already had. When I called back later another tech salesperson told be they weren't supposed to say that but could sell me a 5200 lb rated one which was a completely different axle. We also know that the 3000 lb ones on the light rPods are the same axle as the 3500 lb ones, just with a different rating. So there is certainly some spec derating going on here at times.
Then there is the known issue with inboard mounting on the axle tube on the rPods which the Vibes and the new 195 will improve. So, is this new 195 axle really a different axle or is this specsmanship or is it mounting point differences? A big hint would be (assuming its from Lippert) is if its got 6 lugs or 5. Better would be to get the part number from it. That will tell us if its fundamentally the same axle as the 3500 lb ones we have on the current pods or from their next higher 5200 lb product line. |
Page 123 8> |
