Topic: interior led push dome light replacement Posted: 17 May 2019 at 9:12am |
Rather than add a filter, you could look into getting bulbs with a lower color temperature. Its measured in degrees Kelvin. This link explains the scale.
EchoGale
Posted: 17 May 2019 at 8:46am |
If you do it, try first with a piece of plastic cut to fit in the fixture. That way if you don't like it you won't have messed up your light. I just mounted a couple of lights that run on rechargeable batteries that are softer. Sometimes I need the bright light.
Julie
mhfnet
Posted: 17 May 2019 at 8:21am |
The one issue for me with these lights is they are so stark white, which is harsh on the eyes. I wish there was a way to make the light warmer? I was thinking on spraying on a t ranslucent paint or taping the inside of the caps with something to warm them up? Any ideas?
Maybe something like this? Only issue will it be too yellow and not warm like normal warm lights.
PodBarb
Posted: 06 May 2019 at 7:08pm |
No issue with lights, just anticipating replacing one at some point. Thanks!
2017 RPod 171
2017 Kia Sorento SX
PodBarb
Posted: 06 May 2019 at 7:07pm |
Hi. I ordered on Amazon as suggested and received two replacements. No issue, just want backups.
2017 RPod 171
2017 Kia Sorento SX
Posted: 06 May 2019 at 6:00pm |
I had one fail, switch was bad and light would not shut off, kind of:) I replaced it.
DWSQRD
Posted: 06 May 2019 at 5:26pm |
Yep, I have replaced one. Found a Camping World near me and bought one for about $10. You need a #2 Phillips screwdriver, wire stripers and 2 orange wire nuts. Less than 10 minutes. I noticed the new one has a different switch. No clicking when pressed. Out of curiosity, are you replacing yours because water got into it? That's what happened to mine so I got up on the roof and applied some of that spray sealant you see advertised on TV around the exhaust fan housing. Happy Camping.
PodBarb
Posted: 30 Apr 2019 at 6:38pm |
BTW, honestly I use only the one over the sink and thought it might give out. But I like having spares. Now looking for light bulb replacements for outside trailer lights. Replaced two, but not sure if same bulb is used for all outside lights. Perhaps you also would know this?!? Thanks again
2017 RPod 171
2017 Kia Sorento SX
PodBarb
Posted: 30 Apr 2019 at 6:29pm |
Fantastic, Perfect! Thanks for your help!
2017 RPod 171
2017 Kia Sorento SX
Ben Herman
Posted: 30 Apr 2019 at 6:10pm |
Here's the link to them on Amazon.
