FRIDGE ON PROPANE |
Kup-Pod
Senior Member Joined: 08 Jun 2017 Location: Guelph, Ontario Online Status: Offline Posts: 153 |
Topic: FRIDGE ON PROPANE Posted: 02 Jul 2019 at 5:52pm |
Fair enough on the wire comment, thanks Stephen.
Glad to hear you got it cleared up Jon
2017 RP-178
2021 F150 5.0l "Lead me on a level path" |
Posted: 01 Jul 2019 at 8:58pm |
hogone
Senior Member Joined: 09 Apr 2013 Location: St. Louis Online Status: Offline Posts: 1049 |
Posted: 01 Jul 2019 at 7:32pm |
burning stronger than ever! hogone
Jon & Pam
hogone
Posted: 01 Jul 2019 at 5:26pm |
podwertz: yup, they work strong!!!! and gas water heater. out to tear it up again as we speak!! hogone
Jon & Pam
podwerkz
Posted: 01 Jul 2019 at 1:12pm |
Is the furnace and the stove working?
Posted: 01 Jul 2019 at 7:45am |
Not knowing just where and how you used the compressed air, make sure the chimney is clean. Run a rag up and down it, etc. I was surprised how little of a amount it takes to disturb the flow and keep the thing from running right.
Kup-Pod
Posted: 01 Jul 2019 at 5:47am |
In my old tent trailer I used to get tiny spider webs in the burner orifices that were quite sticky. Compressed air may have blew through them but not cleaned the, out completely. Maybe the gas is getting through but not at a sustainable volume. It would be worthwhile to clean the burners orifices with a wire.
2017 RP-178
If its clean and makes a good blue flame initially but then goes out it after a few seconds it could be the flame detection signal, which is there to sense whether the flame is lit or not and shut off the gas if not. I think the signal is produced by a thermocouple. You can disconnect the thermocouple and check it with a multimeter on the millivolts setting. I think is should be producing about 25 millivolts but I could be mis-remembering.
hogone
Posted: 01 Jul 2019 at 5:19am |
I attempted to clean burner area and used some compressed air to no avail. Attempts to light, may stay lit for a couple seconds but goes out. Thoughts, hogone
Jon & Pam
