Page 12> |
![]() Posted: 19 Aug 2020 at 8:38am |
Be sure to shut off the electric mode when not in use, if you accidentally run it with the water heater tank empty it will burn up your heating element. You can use the dedicated circuit breaker in the rpod panel to turn it off if you don't want to go outside and use the switch.
BeagleMom ![]() Newbie ![]() ![]() Joined: 17 Aug 2020 Location: New Mexico Online Status: Offline Posts: 3 |
Never tried on electric mode. Will try!
Woody the beagle Mom
Good to laugh! Still trying to solve problem!
Pod_Geek ![]() Senior Member ![]() Joined: 04 Dec 2019 Location: Colorado Online Status: Offline Posts: 260 |
So now I'm in hot water.
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L |
Just an old plumber's joke, not to be taken seriously....
Once the really hot water starts to cool off it becomes just hot water and needs to be heated back up...
Its a water heater not a hot water heater. If the water was already hot it wouldn't need to be heated.
Ruberu ![]() Newbie ![]() Joined: 20 Nov 2017 Online Status: Offline Posts: 2 |
17 1/2 Rpod 180 Hood River
My Propane line going to the water heater was kinked from the factory. Might be worth a look
180 Hood River
2014 Pilot Nav 4WD |
If the water isn't hot at the tap, then check the position of the bypass valves. The ones leading to the top and bottom of the water heater should both be parallel to the lines. The one between should be perpendicular to the line. If the one between is parallel, then hot and cold water are being mixed and the best you will get is warm water.
podwerkz ![]() Senior Member ![]() ![]() Joined: 11 Mar 2019 Location: Texas Online Status: Offline Posts: 966 |
Besides the above question, we also need to know if the burner is coming on, and staying on for at least 5-10 minutes or so, when in propane mode.
If the water is already hot from the electric element being on, then the burner wont need to be on for very long.
Page 12> |
