  New Posts New Posts RSS Feed: How to access the Jensen radio in RP180
Topic ClosedHow to access the Jensen radio in RP180
brownjen View Drop Down
Direct Link To This Post Topic: How to access the Jensen radio in RP180
    Posted: 13 Oct 2020 at 9:20am
Ken in Vermont
Direct Link To This Post Posted: 13 Oct 2020 at 9:20am
Got it!  Thanks.
And all the wiring is right!
Ken
Ken in Vermont
Direct Link To This Post Posted: 13 Oct 2020 at 9:19am
Thanks for the suggestions. Indeed the speaker was not connected... However, even after I connected the wires it remained unresponsive. So... more work to do. I pulled the Jensen out far enough to see that the mass of wires  was not as simple as my old sterioWink.  I'm going to need some help, I'm afraid. Plus I discover that one of the two ceiling speakers inside the camper is not working. I switched the two interiors, and it's not the speaker -- it's the wiring, the connection, or the Jensen.
As least I'm narrowing it down.
Ken
And thanks for the tip on the dicor.
Ken in Vermont
lostagain View Drop Down
Direct Link To This Post Posted: 28 Sep 2020 at 9:59am
+ 1 to checking the speaker connections first.  We had a silent speaker and when I pulled it off, I found one of the wires was not plugged onto the spade lug on the speaker.  When you pull off the speaker, be sure to have some dicor to reseal it.  Silicone caulk doesn't work well for that purpose.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Colt View Drop Down
Direct Link To This Post Posted: 28 Sep 2020 at 12:54am
Check the connections at the speaker first.
To access the rear of the radio, open the left most door To the cabinet above the dinette. There is a plate inside that is held in by one or 2 screws. Behind it is all the wiring.
John
'16 R-Pod 180
podwerkz View Drop Down
Direct Link To This Post Posted: 27 Sep 2020 at 5:13pm
I would test that exterior speaker first.
Pod People View Drop Down
Direct Link To This Post Posted: 27 Sep 2020 at 4:55pm
I don't know about your model, but ours is in the 179. I took the radio out by unscrewing the four square headed screws on the face plate.  the screws are deeply recessed in each corner. when you unscrew the 4 screws, the entire radio will come out-not just a faceplate. It's a box about 5" deep with lots of short wires coming out the back.  It's best to have a helper hold the radio while you work on it.  I tried to prop it up on the top of a step ladder but could never get it out that far from the cabinet because of short wires.
Hope this helps
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 27 Sep 2020 at 2:04pm
Any clues on how to access the back of the Jensen AWM968 radio in a RP180? One of the exterior speakers is not working and I'm guessing the place to start looking is the cable hookups on the back of the radio. Can't figure out how to access them however. Maybe just start unscrewing all the screws on the faceplate? Thought I might do well to ask first.
Ken in Vermont
