  New Posts New Posts RSS Feed: 2020 171 water heater
Topic Closed2020 171 water heater
lostagain View Drop Down
Direct Link To This Post Topic: 2020 171 water heater
    Posted: 28 Sep 2020 at 10:07am
Be sure to relieve the pressure on the water heater before you loosen the anode rod or you'll get quite a squirt.  Lift the little handle on the pressure relief valve and let the pressure dissipate.  It only takes a second.
On our 2009, 172 there was a middle valve, but it was eliminated in subsequent years as it was a waste of materials and labor and not needed to bypass the water heater.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
podwerkz View Drop Down
Direct Link To This Post Posted: 27 Sep 2020 at 9:54pm
Are you talking about the valve that is for the suction line? It should be there....somewhere...
Direct Link To This Post Posted: 27 Sep 2020 at 6:58pm
Curious as to when FR went to the 2 valve system.  Has it been quite a few years?
Direct Link To This Post Posted: 27 Sep 2020 at 5:45pm
No middle valve, you're good. A middle valve would be a mixing valve to mix hot and cold water. Just take out the anode now to drain the tank.
JoeSaint View Drop Down
Direct Link To This Post Posted: 27 Sep 2020 at 5:39pm
I just winterized my 2020 171, and there is no “middle” bypass valve? Just one at the top and one at the bottom? So I just turned them both off which sends the water past the heater. But I thought there was supposed to be one in the middle?
