Oven replacement |
Post Reply | Page 12> |
MitchReef
Newbie Joined: 15 Sep 2020 Location: Oviedo, FL Online Status: Offline Posts: 27 |
Topic: Oven replacement Posted: 11 Mar 2021 at 4:07pm |
I believe they carry a relatively inexpensive Dometic and a more expensive (almost twice) Furrion. I will read up about both and any others that I consider. Just came for possible advice. I know how to get this one out. The trim attached to the wall with woodscrews, but also to the oven, so both come out together. Found that when one of the screws came out of the oven and it twisted around.
Mitch and Laurie Carter....
Still rolling.... |
Posted: 11 Mar 2021 at 4:00pm |
That is way to go, but best if it is a RV microwave, as indicated by venting. I haven't shopped for one.
MitchReef
Posted: 11 Mar 2021 at 3:57pm |
I believe I can get one from Amazon a bit better price but I would have to shop them.
Still rolling.... |
Posted: 11 Mar 2021 at 3:52pm |
I stayed at a campground a couple years back, and a guy with a motorhome replaced all the furniture in his RV from RecPro, remodeled the whole thing.
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3255 |
Posted: 11 Mar 2021 at 2:22pm |
Wow, that is a lot of weight. When we ordered our 177 back in January 2011 we ordered it without the oven (47 lbs) no A/C (around 100 lbs) and no entertainment system (guessing 35-40 lbs?) and since then no regrets. No wonder ours feels like flying sometimes
pedwards2932
Senior Member Joined: 21 Sep 2020 Online Status: Offline Posts: 333 |
Posted: 11 Mar 2021 at 12:27pm |
We have the HighPoine convection/microwave......if you run the microwave for a long period (10 min) it has a thermal protection shut down and you have to wait about 10 minutes for it to reset. Really annoying.
Posted: 11 Mar 2021 at 11:47am |
Thanks. I had not heard of that site. The convection-microwave they sell is a HighPointe which is what came with our RPod. You can see the difference between the convection-microwave and the microwave there by looking at the two models. The Convection-Microwave has additional ductwork.
Posted: 11 Mar 2021 at 11:22am |
On the internet, there is a site RecPro, they sell parts, to include micros to restore/repair RVs.
podwerkz
Posted: 11 Mar 2021 at 11:09am |
You need to limit your options to an RV rated convection/microwave because they have a front or faceplace vent system: there is usually a metal duct that actually directs hot moist air out thru the trim plate or the front of the unit.
You could use an off-the-shelf household unit, but you would need to fabricate a vent system as well as a mounting system. I simply removed mine permanently and that space is now much needed additional storage. I lined the interior of that space with some paneling I had on hand and added 2 USB ports and an LED light. Very handy! Not to mention I got rid of a 47 pound oven that was almost useless when boondocking. Freeing up 47 pounds of deadweight means I can carry lots of additional food and water and cooking utensils.
Posted: 11 Mar 2021 at 10:49am |
Ours was replaced twice, but not by me. The first was when it wasn't working right within the 1 year warranty period. The second was when it went to the factory and they said that it did not pass an electrical systems test. Since then, it has been working well, so I do not know what went wrong. I had not heard of that problem, so it is likely somewhat unique. It should not be hard to replace the convection-microwave though. It should be fairly easy once you remove the trim ring.
