  New Posts New Posts RSS Feed: A couple questions about solar
Topic ClosedA couple questions about solar
Direct Link To This Post Topic: A couple questions about solar
    Posted: 20 Sep 2021 at 10:50pm
+1. Or just don't use the Zamp port which just increases your wire length and resistance losses unnecessarily, and wire your solar directly to the battery (via a fuse as Colt suggests).
Colt View Drop Down
Direct Link To This Post Posted: 20 Sep 2021 at 6:51pm
That is just a connection to the battery (with the polarity reversed, use caution). You'll need a charge controller and panels. And a fuse.
John
'16 R-Pod 180
biggestjosh View Drop Down
Direct Link To This Post Posted: 20 Sep 2021 at 4:01pm
My 2016 R-Pod 171 I just picked up came pre-wired for solar (there is a plug port in the rear right outside wall of the trailer with a "Zamp Power" sticker under it).
Does this mean all I have to do is plug in solar panels and it will start charging the battery? Or do I need to wire in a solar charge controller? There isn't one anywhere in the RV that I'm aware of.
