Slide-out info |
Susan_55
Newbie Joined: 01 Dec 2021 Location: Sequim, WA Online Status: Offline Posts: 12 |
Post Options
Quote Reply
Topic: Slide-out info Posted: 14 Jan 2022 at 4:08pm |
Thanks, Ron. I'll get the right size socket so I have room to maneuver. I've had a 5th wheel and a truck camper with slides and never had a problem with them either. I'm assuming our (yours and my) luck will hold. I'm having so much fun with this little Pod!
2014 R-Pod 178 HRE
2015 Toyota Tacoma 4WD V6 on the beautiful Olympic Peninsula, Washington State |
ron_whitt
Senior Member Joined: 08 Sep 2011 Location: Chesterville On Online Status: Offline Posts: 261 |
Post Options Quote Reply Posted: 14 Jan 2022 at 2:37pm |
We have a 2012 177 pod.. Almost the same lay out. To manually move your slide take the cover off underneath the kitchen area just to the left of the fridge. There you will see head of a screw, I believe it is the same size as the stabilizer jack screw heads. It is in a tight area, so I bought a wrench that will work in that small area. We bought our trailer new in 2012, so far... fingers crossed we've never had to do anything manually with our slide.... Good luck with yours also.
Ron & Shirley
2020 Tacoma 2012 177 rpod |
Susan_55
Post Options Quote Reply Posted: 13 Jan 2022 at 6:12pm |
I'm wondering if there's a manual override on the slide on my 2014 178 HRE. Wanting to be prepared for anything, I like to know BEFORE I have a problem. Can't find anywhere to hand-crank it if I need to. I tried doing some research on maintenance etc. and most of the info refers to a Schwintek slide. Mine says "Venture" on the motor. Same company? Any info or suggestions are welcome!
2014 R-Pod 178 HRE
