Microwave Outlet |
sbeninga ![]() Newbie ![]() Joined: 08 Jan 2020 Online Status: Offline Posts: 23 |
![]() ![]() ![]() ![]() Posted: 22 Mar 2022 at 1:57pm |
----------------- Thank you Alan for your reply!!
I had a similar issue with the fridge in my 179, which is also in the slide. I no longer have that R-Pod, but as far as I know, the issue still exists. Fortunately, the fridge still worked on propane and battery/converter power. I think that the wiring protection is not good going into the slide; I was able to determine that the outlet was dead. Without pulling apart more of the Pod than I wanted to, there was no way to trace it.
BTW, the GFCI should have no impact on the microwave because it's usually on a dedicated circuit. It was in my 179 anyway.
Alan
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6298 |
Thanks for the additional information. It is possible that there is a wiring issue if it works sometimes. Those are the most difficult problems to find. If you are not comfortable working on this yourself, take it to a place that can diagnose the problem and fix it for you. That might not necessarily be a dealer. There might be an independent RV service place near you. It could be as simple as the wiring in the outlet is not tight and when the slide moves, the wire shifts from making contact to not making contact. Alternately, it may have flexed enough to break. Personally, I would take the outlet out (with power turned off, of course) and check the tightness of the cable where it attaches to the outlet.
Here is something you might try. Pull the microwave out. Plug in the fan or a small light, something like a night light. Operate the slide while watching the fan or light. That should help you figure out if it is the slide movement that is causing the problem. I would still check the outlet first.
Yes, I was plugged into shore power each time that I experienced the problem. I am thinking that it has to do with the wiring (which concerns me). The kitchen in a 190 is on the slide and it seemed like I noticed that moving the slide in or out one time made the outlet work or not again. I did check the breakers and the GFI outlet that is in the bathroom.
Okay. were you plugged into shore power while doing this? The microwave will only work if it has AC power. If you are plugged into shore power, are there any breakers tripped? If no breakers are tripped, check the GFI outlet to make sure that is not tripped.
I need some help regarding the outlet that my microwave plugs into. I have a 2019 R-Pod 190. During my last 3-week trip my microwave worked at times and other times it did not. I was traveling with a friend and she helped me to loosen the trim around the microwave. We then pulled the microwave out enough for her to reach in and make sure that it was plugged in all the way and it was. We plugged a small fan into the outlet and it did not work either so that told us that it was not the microwave. Has anyone else had this problem and what was your solution? Thank you for your help!
