Moving Lithium batteries to under bench seat |
Post Reply | Page 12> |
Post Options
Quote Reply
Topic: Moving Lithium batteries to under bench seat Posted: 31 May 2022 at 6:49pm |
I was one of the authors of the solar part of the NEC (article 690) back in the day. That was an interesting experience, you can imagine the process involved in getting Code written. Harder than hearding cats.
The first place to put a cb or fuse is the battery + terminal. That would be the source of the highest fault current. I recommend a bolt on fuse right at the terminal but if not as close as possible. So you don't need a fuse or cb on the DC/DC output since it is current limited but you do need one at the battery end of that circuit. You would however need one on the output if the installation instructions require it, because the instructions are part of the UL listing for the product, if not installed properly the product is not listed. So you need to follow both the NEC and the listings of the products when you install electrical systems. The thought process when designing overcurrent protection with multiple sources is to imagine a fault on each conductor and then tracing back in all directions to any sources of energy that could feed into that fault. Each and every conductor has to have properly sized overcurrent protection between it and the sources. The "25%" rule is to avoid nuisance cb trips or fuses blowing. So in general start with the max rated current of each device, multiply by 1.25, and pick the next highest available fuse or cb size. Then pick a conductor size with that ampacity or higher. For low voltage systems it's quite common to go higher in order to keep the voltage drops down. That's especially true for the long cable to a portable solar setup. In general you don't want the voltage drop on a circuit to be more than about 5%,or 0.6V on a 12V circuit for example. Yes I think the 20A DC/DC might be a bit much for a 20A supply circuit. You might want to see if you can either set it's max current a little lower if it's adjustable or return it and get one with a slightly lower current rating. Or run a new 10 gauge line via a 30A cb from the TV battery to the 12V 7 way pin. Then from the trailer side of the pin to the DC/DC input. You could still use the unused 7 way reverse pin to turn the DC/DC on and off. |
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6298 |
Post Options Quote Reply Posted: 31 May 2022 at 4:09pm |
I ran a dedicated 12V circuit when I installed my DC to DC charger. I installed a battery isolation solenoid in my Frontier to control it. The solenoid is triggered when the vehicle is started and de-energizes when the ignition is off. It goes to a 2-pole socket on the back of the Frontier and I ran a dedicated circuit for the DC to DC charger in the RPod that connects to that socket. Since it is only active when the vehicle is running, I could pull the trigger voltage for the DC to DC charger from that also without having to run another wire up to the vehicle. It was probably more complicated than it needed to be, but it works and works reliably.
Ibcj
Newbie Joined: 01 Sep 2021 Location: CA Online Status: Offline Posts: 5 |
Post Options Quote Reply Posted: 31 May 2022 at 1:29pm |
I pulled the schematics for my primary TV to be sure, and the good news is that there is a dedicated fuse for the tow connector and a relay that is energized only when the truck is in the run position. The bad news is that it is a 20A fuse, and not a 30A circuit, which may not work with the 20A DC-to-DC convertor I purchased.
And thank you for mentioning the circuit protection; it has been part of my plan, I just hadn't gotten around to planning it yet. I do actually read the NEC from time to time . Of course adding in a 12V distribution system, and putting the whole thing on wheels is uncharted territory for me... Here's my current thinking: AC Converter (60A): use short run (1-2ft) of 6ga with a 75A (?) circuit breaker DC-to-DC Converter (20A): use a short run (1-2ft) of 10ga with a 25A (?) circuit breaker. Not sure yet how I want to run the DC-to-DC output (directly to the battery behind a battery cutoff switch or infront of the switch to provide house power when the battery is disconnected). Also not sure of these CB values above - both values are well under-current for what the wire and battery can handle, but figuring the devices could push up to 20% past their rated output? I may be entirely wrong on this though. I'm also not sure if I should protect the +12V connection from the TV that comes through the 7-pin. In theory it is fused on the TV, and because it is connected to the DC input on the DC-to-DC converter I assume it won't be energized even when the battery connected to the DC output is. Assuming this is true, then I don't think I need any protection on this circuit. RE: coffee - the offer stands for the next time you visit the west coast! Thank you!!
2021 r-pod 193
Post Options Quote Reply Posted: 31 May 2022 at 12:23pm |
I don't think you're missing anything. My 12V pin is always hot. Sounds like if yours is hot only when the ignition is on that you're good to go without any relays or any anything else.
Ibcj
Post Options Quote Reply Posted: 31 May 2022 at 11:01am |
I made the assumption that the 12V pin on the 7-pin trailer connector was always hot, regardless of TV ignition status, and that was why you folks put a relay on the pin. It appears that pin is only hot when the vehicle is keyed on. Since I never leave my vehicle in the on position when the engine isn’t running, it seems like the chances of the TT killing the TV battery are pretty slim, no? What am I missing?
2021 r-pod 193
Post Options Quote Reply Posted: 31 May 2022 at 6:57am |
Yes those are most likely the preinstalled lines for a roof mount solar installation. However, you know what they say about assuming so I would ring them out with an ohmmeter to be sure.
You could place your DC/DC in the TV where you have ready access to a wire that is hot when the ignition is on. Alternatively, I don't think the reverse light pin on the rpod seven way is being used for anything (it wasn't in mine anyway) so maybe you could repurpose that one. It sounds like you are working everything through. Apologies in advance but I'll mention it here in case you or others who read this don't know. The purpose of breakers and fuses (in general, overcurrent protection devices) in the NEC (national electric code) is to protect the conductors. The connected devices are supposed to be UL listed and include (or you add per the install instructions) whatever additional overcurrent protection they might require. So when you run circuits, you need to protect those wires from ever seeing current beyond their ratings. This applies to both 12Vdc systems as well as 120/240Vac. You have to protect the conductors from overcurrent from all energy sources. In our 12V RVs that means the TV battery/alternator, the house battery, the charger, and a solar system if you have one. So, trace all conductors back to their sources, and be sure all the wires have appropriately sized breakers or fuses protecting them. Of course, you don't need to add additional overcurrent protection for individual conductors if there is already a cb or fuse upstream that does the job. Since I'm in VA and youre in CA I'll take a raincheck on that coffee. |
Ibcj
Post Options Quote Reply Posted: 31 May 2022 at 1:13am |
Appreciate your thoughts offgrid; learning through your experiences is saving me a bunch of mistakes already!
So I tore apart the front under-belly access panel as well as the WFCO power distribution unit today and started mapping out the wires, circuit breakers, and tracing out as much as I could see. I feel much more comfortable about what it will take to put the LiFePO4 batteries into the TT now. Coming from the battery there were two sets of leads on each post. The "primary" set was 8ga, and one ran directly to a chassis ground, the other into a couple short stops just inside the trailer floor under the front access panel. The other two leads are 10ga and run along the frame with the rest of the wiring after also going through a short stop in the access panel. I see matching 10ga red & black leads come up from the floor behind the WFCO and run up the wall next to the pantry. Best I can guess, these are the leads for the solar hookups on the roof. Any other ideas/suggestions for what these could be? I ran out of daylight, but will continuity test them tomorrow. On the 193, there's a lovely compartment under the furnace that would be kind of be perfect for the Li battery. I'm pretty sure that it's the solar roof wiring (from above) that runs through there, it is next to the WFCO, and is otherwise unused space. Unfortunately the ridiculous huge Renogy 200Ah battery I bought won't fit unless I move around some PEX supply lines, and that juice just doesn't feel worth the squeeze. So best option I can see is to put the Li battery and supporting equipment under the front couch, in the LH corner, which is where the water pump is located (easy access to the underbelly). I haven't been able to get anyone from Renogy on the phone, and I can find any recommendations from them on what charge controller to use. So my thought is go with a 60A Progressive Dynamics Li Charge Controller (PD9160ALV) which should only pull ~9A on 110, so that gives me plenty of safety margin on a 15A/14ga circuit (the 80A version notes it needs a 20A circuit and would pull ~11.8A, so cutting it too close I suspect). I'm going to call the PD guys tomorrow. The Renogy looks to have a decent (I think?) integrated BMS, so I'm guessing it will be safe inside the TT. And from what I've read, the LiFePO4's are way less likely to ignite than other Li options - but I'm green on this so looking for comments! I'm sorry that the WFCO's fried your batteries. That's a bummer. My WFCO integrated converter looks easy to disconnect, so I'll mount the DC-to-DC converter and the PD Charge Controller next to the battery under the front couch. I think the trickiest part will be pulling a "home run" of Romex from the WFCO panel to the charge controller under the bed. I'm going to try to do it with a nut on pull rope, and using a magnet on the underbelly. More likely I'll have to cut a couple access holes. Murphy's Law tells me I'll end up dropping the entire underbelly and then wishing I hadn't. Would welcome advice on this! And now I realize that if I'm pulling romex anyway, I could pull 12ga and run a proper 20a circuit for the converter and go with the 80A converter.... Sigh. I'm going to run the DC-to-DC converter from the TV as you suggested, but I'm thinking about running it through the OE BlueSea 6006 single-circuit cutoff switch on the front of the trailer (the +12V from the 7-pin would be the only thing running through it). This way I can turn off the charge circuit and not worry about killing a TV battery. For my primary TV, I do plan on running a relay to feed the +12V on the trailer connector with an override switch, but I'd like to have something on the TT for when we aren't using my primary TV. Seems like the right thing to do. The DC-to-DC controller I bought has a trigger wire on it, so that you can tell it only to operate when the trigger wire is hot. Sadly, there's nothing on the 7-pin (from what I can tell) that tells you the TV is running. This is super disappointing. I could hack it and use the taillights/running lights wire, then the TT would only change when the TV lights are on. This isn't the worst idea as my TT cameras are dropped in to existing running light locations, so they only work when the lights are on. Hopefully tomorrow I can get the PD ordered, then map out what kind of circuit protection I need where. I'm somewhat optimistic I can get this done in the next 10d before my next trip - otherwise I'm going to have to slap a lead-acid on the front for a single-time use so that I can camp in the shade without running the genny! Thanks again for listening and all your comments - super helpful! Coffee and/or beer on me anytime!
2021 r-pod 193
Post Options Quote Reply Posted: 28 May 2022 at 4:18am |
Generally speaking, Li batteries don't need a multistage charging profile, unlike lead acid batteries. PbA batts do because their internal resistance increases dramatically as they near full charge, so you have to taper the current to get them there. They also need a small continuous (or at least frequent) float charge current or they will self discharge and the individual battery cells will become imbalanced. The continuous float charge corrects this by slightly overcharging some cells, allowing the others to get to full charge. Finally flooded PbA's need an occasional equalization charge at a highrr voltage to mix the electrolyte, which tends to stratify (sulfuric acid is heavier than water) otherwise. Simply put PbAs both tolerate and need some overcharging to perform properly and last.
OTOH, Li batteries can simply be charged up to a set voltage and stopped unless you are trying to recharge them at a very high rate (like in an EV fast charge station). It is harmful/dangerous to charge Li batts higher than that. That means a different approach has to be taken to assure cell to cell balance another approach is needed. This is an electronic cell balancer which should come integrated into any Li battery you buy. These usually (but not always) also come with a high voltage cutoff to prevent overcharging in the event your charger malfunctions. Some also monitor battery temp and limit charging when the battery is too cold. So simply put Li batteries don't tolerate or need overcharging. I'd suggest that you let the charging revommendations spec'd by your battery supplier set the direction you take for the charger(s) you get. Re WFCO, I am one who has had my lead acid batteries overcharged by a failed charger. Mine went to around 16-16.5V and stayed there. Luckily I had flooded golf cart batteries, happened to hear and smell my batteries overcharging, found my battery plates to be nearly exposed, and added water in time so no harm done, but it couldn't have been more than a week since I'd last looked. If those had been Li batteries without internal over voltage protection they would almost certainly have been destroyed or caught fire. So I don't trust WFCO chargers personally, and I also wouldn't install Li batteries inside the trailer unless they were internally protected. Too much fire risk for me. I think a 20A DC/DC is fine. Note though that it will continue to try to charge your trailer batteries even after you shut off the TV, unless you disconnect the 7 way or add a relay energized by the TV ignition circuit to automatically disconnect for you. Stopping for a few minutes to fuel up will be fine but if you stop for an hour or two or longer on the road I'd be sure to disconnect. Disconnect or cut the +12V conductor on the trailer side of the 7 way before it connects to anything else and run that to your positive DC/DC input. Then run the dcdc + output to the trailer side of the line you disconnected and you should be fine. |
Ibcj
Post Options Quote Reply Posted: 27 May 2022 at 11:14pm |
Super helpful, thanks to you both for your quick responses here.
I looked at the charging profiles for both the WF-8735P and WF-8735AD and the three-stage profile is the same on both. It seems that this would be safe for a Li battery, just not optimal, which would allow me to safely run the WF-8735P with the Li battery. Here's what I'm basing this on: More in the AD manual here. There are a couple board posts that have mentioned the WFCO units (I presume the P units, not the dual AD units) that have fried batteries by, presumably, the charge controller going haywire. There was a post that mentioned swapping out the charge controller board in the WFCO with something from Progressive Dynamics, but I haven't chased that down fully yet. Seems the easiest path is to just replace the WF-8735P with the WF-8735AD and for the minimal extra cost, get some modicum of safety knowing it is using the two-stage charging for Li. Any suggestions are welcomed! I'm also assuming to get access to this wiring I should start by dropping the bottom corrugated plastic board from the r-pod - something I haven't done yet. I've pulled out the WF-8735P once, and that visual gave me hives. offgrid: I have purchased a DC-to-DC charger. I went with 20A, which assuming that is the output current, should keep me safely under the 30A that I can pull through the 7-wire. I also have a Renogy 100W suitcase solar charger that has a Li mode on the charge controller, so I feel comfortable there. Interesting about the brake trailer controller circuit switch when the pin is pulled, I always wondered about that. Hopefully there are no assembly gremlins around the 7-pin pigtail on the TT and I don't have to monkey with that. But given that I found out today that the output side of my fresh water pump has been leaking from the fitting that was never tightened, I'm not optimistic that I won't find more gremlins in the wiring.
2021 r-pod 193
Post Options Quote Reply Posted: 27 May 2022 at 8:01pm |
You do want to install a converter configured for Li battery charging. There is too much risk from overcharging Li batteries. Placing them in a temperature regulated space is a good idea, Li batteries don't like to be charged at low (below freezing) temps.There are now self heating Li batteries available now but why waste energy?
The issue regarding charge profile for Li batteries applies to all your charge sources, including solar and tow vehicle charging if you plan to use those. Most solar charge controllers these days have a Li setting, but proper charging from an alternator/TV battery requires installation of a DC DC converter. That should connect directly to the tow vehicle 12V charge conductor as exits the 7 way connector, and no trailer circuits should be connected directly to the TV 12V supply before the DC DC converter, with the exception of the turn signals, marker, tail, and brake lights, which are never connected to the trailer battery. The interesting execption to this is the electric trailer brakes, which are normally supplied from the TV battery via the brake controller, unless the brakeaway pin is pulled in which case they switch over to the trailer battery. This circuit shouldn't need any modification when converting to Li, just thought I'd mention it because of it's unique status. |
