Move Freshwater Tank Drain |
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3237 |
Post Options
Quote Reply
Topic: Move Freshwater Tank Drain Posted: 25 Jun 2023 at 6:31am |
We simply locate a steep grade and drive across it laterally and ALL the water comes out of the FW tank. Much easier process than attempting to drill and safely install a new drain (that wouldn't leak) at the bottom of the tank.
Colt
Post Options Quote Reply Posted: 24 Jun 2023 at 5:22pm |
I doubt you can move it, but you might add another one. Not sure how you're gonna get inside it to install a very low profile inside flange so the last bit will drain out. Maybe use a jack(s) to tilt the whole trailer?
John
'16 R-Pod 180 |
Modogsb
Newbie Joined: 10 Jul 2016 Location: CA Online Status: Offline Posts: 5 |
Post Options Quote Reply Posted: 18 Jun 2023 at 9:53am |
Hi,
I’d like to thoroughly drain the freshwater tank after use… to reduce the algae buildup. Has anyone moved their drain valve to the center of the tank? Thanks |
