Sharing a weird elec.issue: turn signal reversed |
renhui
Groupie Joined: 20 Jul 2022 Location: Calgary, Canada Online Status: Offline Posts: 62 |
Post Options
Quote Reply
Topic: Sharing a weird elec.issue: turn signal reversed Posted: 14 May 2024 at 3:11pm |
Just want to share a recent episode on electrical issue.
I was getting ready for the upcoming camping trip, and hooked up the Rpod to my TV. Checking the lights and a very weird thing happened, left signal would turn on the right signal light, and vice verse. Also there is no 12v coming into the RV. Checked all the fuses on the Rpod, didn't find anything wrong. Ended up cleaning off the contacts of the 7-pin plug, and turn signal lights now work as expected. For the 12v, it turned out that the main fuse on the TV is blown (not sure if it's related to the turn signal issue), replaced the fuse and everything back to normal. On a related note, last year, after hooking up the battery, I noticed the night lights are on without TV hooked up, and it turned out water get into the 7-pin plug and blew a fuse in the Rpod. Hope this could help some Rpodders with similar electrical issues.
2016 Rpod 178 HRE
2018 Honda Pilot AWD |
