Batteries question 12 vs 6v |
gpokluda
Senior Member Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 326 |
Post Options
Quote Reply
Topic: Batteries question 12 vs 6v Posted: Today at 8:35am |
You will get all kinds of opinions on this. There are some old-schoolers that think two 6 volt batteries are the beez kneez. I had two 12v batteries as you have now and never had an issue. This debate rages on the Escape forum as well.
What I do know is that the age difference between your two batteries could prove to be a problem. Batteries in a battery bank should be close in age.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Kawasaki KLR650 |
Riobug
Newbie Joined: 06 Apr 2024 Location: NM Online Status: Offline Posts: 1 |
Post Options Quote Reply Posted: Today at 8:18am |
Do not know about the battery charge, etc., but a major reason for using 6v in a boat is that, for comparable energy, one can actually lift the batteries without a crane and fit them in cramped spaces.
If your 12 volts fit and have a tough case then probably good enough for the next 3-5 years.
Gulo
Newbie Joined: 24 Feb 2024 Location: Washington Online Status: Offline Posts: 1 |
Post Options Quote Reply Posted: Yesterday at 9:05pm |
I have an Rpod 178. Recently both 6v golf cart batteries died while in a remote location. The best battery I could find within 100 miles was a 12v deep cell battery for boats and RV's. I changed the cables around and made it work to get home but am now considering refitting the battery system. I now have two 12V deep cell batteries that will fit nicely into my battery boxes when wired in parallel. One is three days old, one about a year, both in good condition. These are batteries supposedly designed for use with boats or RVs. My local RV guy tells me I should use two 6v golf cart batteries because they will give me "a deeper charge" whatever that means. I am mostly using shore power when camping, which is why I didn't realize my old batteries were toast.
I'm wondering, a.) whether what my RV guy says is true and b.) whether it is worth buying two new 6v batteries and letting two good 12v batteries sit on the bench and c.) what are the advantages/disadvantages of 6v vs 12v?
Can you tell I'm new to this stuff? |
