Did you know??? |
Topic: Did you know??? Posted: 09 Jan 2012 at 11:59am |
If you are measuring from the end of the AC plug outside, several things I mentioned above are still a factor - even if off. The converter has an internal loss converting from AC to DC. I don't know the exact amount, but modern converters loose around 7%. This loss is carried over to all the other 12 volt appliances so everything uses about 1.07 times more when on AC than when just on battery power. Plus the converter needs some power to run itself, which boosts the reading at the AC plug even more. Even if the fridge is off, its circuitry still uses some power. This is also true of the TV and microwave unless you unplug them (this is commonly called "vampire power", a big problem in homes). So that 23 watts you've measured is more than the LP detector. |
marwayne
Posted: 09 Jan 2012 at 10:03am |
Doug, microwave, fridge, tv,antenna turnd of, batteries taken out.
Posted: 09 Jan 2012 at 7:53am |
Did you measure the propane detector directly, or did you use something like a Kill-A-Watt on the AC plug? If you measured the AC side, don't forget that there are several other loads. Trickle charge on the battery (including losses within the converter), circuitry in the fridge, TV (even if off), antenna amp (if left on). Probably something else that I forgot.
marwayne
Posted: 08 Jan 2012 at 11:15pm |
Did you know when your trailer is plugged in, your propane detector draws 23 watts of power, that means in a month it uses 16.5 KWH.
Did you also know that 1 incandescent lightbulp in your trailer drawes 25 watts, The 172 has 11 of them, if they are all on you are drawing 275 watts. With the switch to LED lights + adding 9 feet of LED striplights I reduced power consumption by 82.5% or to 48watts.
