Noisy pump? |
Post Reply | Page 12> |
Panama Red
Newbie Joined: 20 Apr 2012 Location: Irmo, SC Online Status: Offline Posts: 6 |
Topic: Noisy pump? Posted: 17 May 2012 at 4:57am |
Thank you.
I assume that you are using the same material on your Honda ??? Am I to assume that you covered everything on your Honda, but the intake, exhaust and control panel ???
marwayne
Posted: 17 May 2012 at 12:47am |
First I covered the pump body with SDM (sound deadening matirial), this matirial is a membrane of 1/8" vinyl and 1/4" foam. Than I mounted the pump on a piece SMD, that I mounted on 2 strips of plywood that are screwed to the floor, the pump is floating. Now where ever a tube is touching another tube or a cabinet, wall or anything else put a piece foam around that tube at that spot, if the pump is still banging you mist a spot. The pump should purr like a kitten. Good luck it works. I also reduced the noise level of my 2000watt honda by 50%.
Posted: 16 May 2012 at 10:01pm |
You can get an accumulator tank which will help.
dsmiths
Posted: 16 May 2012 at 8:51pm |
marwayne, I am intrested, I tried techstreks mouse pad under the pump, it helped some, however I thought that most of the noise was from hydralic surge, as the diaphram pump pushed and then quit water would move in a jerky style down the water lines and cause the pipes to jerk, kind of like when the washer in your house slams a valve shut and the water causes the pipes to jerk due to the inertia of the moving water going from 20mph to zero. I though about doing a water column with an air pocket in the lines but it is too much trouble/work for the results. thanks for the tips.
Dane and Donna Smith
Footslogger03
Posted: 16 May 2012 at 4:48pm |
============================ I'm interested !! Thanks, Mark J |
Livin' the Dream ...'Slogger
TIDALWAVE
Posted: 16 May 2012 at 4:29pm |
If a rubber mouse pad is not sufficient, you could mount the pump on a 'sound absorption' pad.
It allows you to bolt the pump to the pad and then using separate bolts, bolt the pad to the floor. That is what I did, it made a big difference in noise level. I also installed some foam insulation sleeves (used on water pipes) on the hoses that run to and from the pump. That also quieted down the pump noise. |
TIDALWAVE
Posted: 16 May 2012 at 11:20am |
One thing to try - if marwayne didn't already do it - is to unscrew the pump from the floor, lay a rubber mouse pad on the floor, and then screw the pump down on top of the mouse pad.
Alex&Marie
Groupie Joined: 25 Feb 2012 Location: Virginia Online Status: Offline Posts: 63 |
Posted: 15 May 2012 at 8:12am |
yes please! the noise is not terrible, but being able to quiet it some would be worth doing, thanks for the efforts to sketch it out for us.
Alex and Marie
2012 R-pod 177 2006 Toyota Tundra |
Alex&Marie
Posted: 15 May 2012 at 8:11am |
Alex and Marie
Panama Red
Posted: 15 May 2012 at 4:57am |
Always appreciate information on how to fix items.
