New Podder-to-be with a couple questions |
Topic: New Podder-to-be with a couple questions Posted: 16 Aug 2012 at 4:55pm |
Sounds like you have the same upgrade plan we did. Knowing we would be taking several loops around the US and:
1) did not want to set up a popup every day (my parents had us do that for 5 weeks when I was a kid)
2) our Sienna wasn't going to make it up the Rockies pulling anything
... we got the pod 3 summers ago, then upgraded the TV this spring. We'll be starting our tours beginning next summer.
P&M
Senior Member Joined: 13 Aug 2012 Location: Spokane, WA Online Status: Offline Posts: 454 |
Posted: 16 Aug 2012 at 4:23pm |
Thanks Sean & techntrek -- that definitely clears it up for me!
P & M ... and Comet too!
P&M
Posted: 16 Aug 2012 at 4:20pm |
Thanks 'Slogger. We know we are going to be pushing it a bit but with only 2 of us doing short weekend type trips, and staying conscious of the weight (packing lite, towing with tanks empty, etc) we think we will be fine for now. I'd love to trade-in and get a larger rated TV but doing that would most likely delay us another year for getting a Pod, and wife is getting anxious to get into one and out of the tent at this point.
I'm definitely planning on upsizing at some point ... probably when we decide we have the time to take off on some longer trips in fall 2013!
Posted: 16 Aug 2012 at 3:45pm |
To expand on that - the receiver is the 2-inch-square opening that is permanently installed on your TV (you don't want to get a 2" hitch & ball permanently installed, but they do exist). The part that goes into the receiver as well as the parts that go on the pod are all part of the WDH system.
My picture above is a bad example because I don't have all of the WDH parts in place, but the large black assembly attached to the rear of my TV is part of what you get when you buy the E2 or Equalizer. There are two long bars that go between it and the pod, but I don't have them installed in that pic. Then there are two brackets that mount on the pod's tongue. You can just barely see them sticking below the tongue, just behind the propane tank.
Seanl
Posted: 16 Aug 2012 at 2:35pm |
You have to have a receiver installed. The WDH goes into the receiver. There are also parts that connect to the tongue of the trailer. |
Footslogger03
Posted: 16 Aug 2012 at 2:04pm |
Just know that with a 3500lb towing capacity you are getting kind of "close". The dry weight of a 177 shouldn't be an issue but when you load your stuff and possibly carry water in the holding tank it's easy to get up near the 3,000 lb level.
'Slogger |
Livin' the Dream ...'Slogger
P&M
Posted: 16 Aug 2012 at 1:51pm |
Thanks for letting me know I'm on the right track. Stupid question though ... is a weight distribution hitch a separate one that I should look at getting installed, or is it a component that attaches to a regular hitch? |
Posted: 15 Aug 2012 at 2:58pm |
Welcome. Looks like everything has been covered - hitch, brake controller, tranny cooler. I highly recommend either the E2 or Equalizer WDH, you will notice a large improvement in ride quality while also gaining sway control.
TerryM
Posted: 15 Aug 2012 at 1:42pm |
As far as the install work goes the friend would be the cheapest I'm sure. As long as he knows what he is doing. The tranny cooler is worth the cost. If you get caught in very slow traffic on a hot day it will pay for itself. After you get the Pod pay attention to how well you can stop when towing. If the Pod seems to be pushing you it might be a good idea to check into better brakes on your TV.
Terry |
P&M
Posted: 15 Aug 2012 at 8:28am |
Good morning everyone! I've been lurking around here for a year now learning as much as I can about the Pods, and my wife & I are now at a point where we are looking to buy a 177 later this fall. However, I need to get my TV in order first which is where I have a couple questions that I am sure y'all can help with. I have a 2008 Hyundai Veracruz 6-cyl with 3500# towing capacity which should be fine for our needs and a 177 (local camping trips, nothing cross-country, taking our time to get there sort of thing). However, it doesn't have a tow package on it and I need to get that all taken care of first. So if I understand it correctly I will need at a minimum the hitch assembly with 2" ball, wiring harness (7-pin) and an electronic brake controller ... right? I am not mechanically inclined myself around cars so I have 3 options for getting it done -- Hyundai dealer, RV dealer or buy the stuff myself and have a mechanic friend install it ... thoughts on which may be best?
For an anti-sway assembly I was thinking of waiting until buying the 177 and getting it then. The only other thing I can think of upfront is that I have seen where some Podders have installed transmission coolers on their TV's ... is that a real necessity based on where we live (NC) and how we will be using it?
Thanks in advance for any assistance, thoughts & comments -- We are really excited about this!
Pat
