  New Posts New Posts RSS Feed: ADVICE-TEMPS
Topic ClosedADVICE-TEMPS - Event Date: 08 Nov 2013 - 15 Nov 2013
hogone View Drop Down
Direct Link To This Post Calendar Event: ADVICE-TEMPS
    Posted: 08 Nov 2013 at 8:59am
thanks, that is what i was hoping to hear........thanks podders!
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 08 Nov 2013 at 8:17am
You might want to take the access panel in front of the water pump off so the pump is more exposed to inside air.   I got rid of the the little pita screws and have my access panels velcroed in place now.  There should be nothing underneath to freeze -- you don't put anti-freeze in the tanks anyway, so you should be okay.
  TT
FJ Cruiser
kymooses View Drop Down
Direct Link To This Post Posted: 08 Nov 2013 at 8:05am
As long as like you said you are keeping the inside warm to protect your water pump I think you're very safe otherwise.
Direct Link To This Post Posted: 08 Nov 2013 at 6:51am
i mentioned in an earlier post i was heading south in a week.  in a couple days though they are predicting upper teens/low 20's for lows (st louis).  I have drained tanks, low water points, drained hw tank,  ran lines dry, and poured some anti freeze down the drains/toilet.  have also run my electric heater already and will do so again during those days.  was hoping not to run af through the system.  think i will be ok?  thoughts/advice!  hogone
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
