Page 12> |
![]() Posted: 31 Mar 2014 at 8:11am |
This was my preference after much research and actually trying several cheaper models.
http://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-18-smd-led-wedge-base-tower/397/ I prefer the warm white color. This model uses 5050 SMD LEDs, are polarity insensitive, and use resistors to limit current. The latter is important in RV applications where the voltage can vary from 11.5 to 14.5 volts. And since individual LEDs are highly directional the 18 SMD tower geometry helps to distribute the light. |
joehung ![]() Newbie ![]() Joined: 22 Sep 2013 Online Status: Offline Posts: 2 |
This is what I bought from ebay:
http://www.ebay.com/itm/261319524030?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 They are pretty bright. I also bought a cheaper version (10-SMD) from the same vendor but it's not as bright. I like these better. The instruction says if it doesn't light up the first time, try switching it around since these LEDs only work with correct polarity. Cheers, -Joe |
Bill-GA ![]() Senior Member ![]() ![]() Joined: 13 Jan 2012 Location: Cumming, GA Online Status: Offline Posts: 214 |
I've used these (5050) types and IMO they are equivalent to old bulbs. 12 devices for each lamp is adequate lighting. Warm lighting is my preference. You can gat 1210 types with MANY more devices but they generate too much heat. Also the price is right!
Bill & Bev
13 yr old dachshund 'Elsa' 2010 RP-176T (tent & slide-out) 2011 Toyota Tundra 2WD TV |
Boomertype ![]() Senior Member ![]() ![]() Joined: 12 Jan 2014 Location: Seattle Online Status: Offline Posts: 108 |
LED's come in varying light output. They are not all created equal.
Here are some that put out 190 lumens. I've seen some that only put out 40 lumens. Also they come in bright white and warm white, I prefer the warm.
dsmiths ![]() Senior Member ![]() ![]() Joined: 10 Oct 2011 Location: Southern Ind Online Status: Offline Posts: 866 |
As earlier stated take out bulb and replace with the led. Make sure lights have been off for a while as incandescent bulbs get really hot. the led bulbs are just warm to the touch after running for an hour. I kept my old ones for back up. I also found that the incandescent bulbs gave a better working light over the stove and the center of the pod over the refrig. We like the leds fine in the bathroom and over the dinette and over the bunks.
Dane and Donna Smith
Robwid ![]() Groupie ![]() Joined: 31 Oct 2011 Location: Oregon Online Status: Offline Posts: 67 |
Svskier,
Did you ever find replacement LED bulbs? Can you make any recommendations? It looks like Camping World has them for about $8 bucks but I hate to pay that much. It looks like the bulb that was recommended to you was a panel light which is a very different shape from our stock 921. Any info would be appreciated. Thanks, Rob
Rob
2012 HRE 177 2010 Toyota Tacoma |
svskier ![]() Newbie ![]() ![]() Joined: 24 Dec 2013 Online Status: Offline Posts: 29 |
Thanks everyone for the input
Literally "plug and play". These will work.. and you are out about $20 to do the whole camper.. Bulbs We have these and love them. |
Thinker ![]() Senior Member ![]() ![]() Joined: 25 Feb 2013 Location: S. Mississippi Online Status: Offline Posts: 171 |
Not so. I have converted all interior bulbs to LED. You pull old one out and insert new one... nothing more. |
is it as simple as just replacing the bulbs?
The man at the parts store told me I would have to install a ballast of some sort in line at the inverter.
Page 12> |
