  New Posts New Posts RSS Feed: Taillight 1/2 full of water?
Topic ClosedTaillight 1/2 full of water?
Goose View Drop Down
Direct Link To This Post Topic: Taillight 1/2 full of water?
    Posted: 08 Mar 2014 at 11:37am
Being brand new, call the dealer and have them replace the light. Sounds like that light has a seal failure and in time will fail completely due to corrosion. Goose
Boomertype View Drop Down
Direct Link To This Post Posted: 07 Mar 2014 at 10:53pm
I don't think I'd drill the hole till you have worked with the dealer.  The may have a fix that involves a seal.  Drilling a hole would interrupt the integrity of the light.  If it was a 93' Volvo with a lens leak I'd drill, but not with something new.
jj View Drop Down
Direct Link To This Post Posted: 07 Mar 2014 at 10:29pm
had same problem last November 2013.
drilled a tiny hole in to the bottom of the lens, water drained out and no more problems.
drilled from the bottom up into the lens.
Direct Link To This Post Posted: 07 Mar 2014 at 10:24pm
Yeah.... things can happen, but, just give the dealer a call.. that is what a warranty is all about.
Direct Link To This Post Posted: 07 Mar 2014 at 10:16pm
Did you contact your dealer?  Sounds like some sort of seal issue.  Get it fixed as soon as possible, you wouldn't want the water to cause an electrical issue.
Ouch
CJPOD View Drop Down
Direct Link To This Post Posted: 07 Mar 2014 at 9:40pm
We just bought our brand new 179 R pod about 3 weeks ago, and our left taillight is half full of water. It's a little disappointing considering we have not even used it yet. Has anyone else had this problem?
