How Level? |
Post Reply | Page 12> |
Keith-N-Dar
Topic: How Level? Posted: 23 Mar 2014 at 7:38pm |
Doug, thanks for posting the picture. That should settle things once and for all!
Keith-N-Dar
David and Danette
podders Helping podders - pHp Joined: 24 Nov 2009 Online Status: Offline Posts: 1218 |
Posted: 23 Mar 2014 at 2:14pm |
I think you all have had to much snow and are getting cabin fever. The best medicine would be Spring time and a chance to go camping.
Posted: 23 Mar 2014 at 12:33pm |
OK.. so you know what is going to happen when you ask about replacement tires, right? |
CharlieM
Posted: 23 Mar 2014 at 11:37am |
Yep! another great discussion topic with opinions ranging from pure VooDoo speculation to pure theoretical science. What did happen to flight 370 anyway . As Doug said, if you're comfortable your fridge is too. At one time there were numbers from a fridge manufacturer: +/- 3 degrees left to right and +/- 6 degrees front to back. Since RV fridges are usually installed sideways in the trailers this means +/- 3 tongue to bumper of the trailer etc. However, I think newer fridges have been designed to better accommodate tilt. When I asked Dometic about this I got the "If you're comfortable...." answer. And even 3 degrees is noticeable to you in the camper. SO: If you don't roll to the end of the camper when you get out of bed you fridge will be happy.
And to the question of towing with propane on or off, I tow with the fridge on propane. My new trailer with a bigger fridge has no 12 volt option. So, if I blow up the world or attract an asteroid I won't care, and neither will the Kymooses, Boomertype or anyone else Nuff' said! |
Posted: 23 Mar 2014 at 11:28am |
Notice the pod and gas station under the trees at the bottom. |
Hairy Podders
Senior Member Joined: 05 Mar 2014 Location: Northwest Ohio Online Status: Offline Posts: 217 |
Posted: 23 Mar 2014 at 9:37am |
As with everything that I research, I read everything & filter out what appears to be nonsense. But I very much enjoy the humor!!
I belong to the popup portal. A great group of people(like here) over there. It is amazing the opinions that one can get answering a simple question about campers/camping. I had read someone else's question about propane fridges over there & they never really got an answer one way or the other. But there were LOTS of opinions! Thanks all for the info & the laughs. |
Darryl, Julie & Lindsey
Cooper & Libby- Devoted Canines 2014 RP178 2006 Wrangler Unlimited Rubicon |
David and Danette
Posted: 23 Mar 2014 at 5:16am |
I hope you were able to make sense of everything and have your question answered. Techntrek's answer is what I would go by.
Boomertype
Senior Member Joined: 12 Jan 2014 Location: Seattle Online Status: Offline Posts: 108 |
Posted: 23 Mar 2014 at 12:39am |
Boomertype
I heard that if you think about propane while reading this thread a astroid will hit the earth. I read it in the internet, it must be true.
dsmiths
Posted: 22 Mar 2014 at 11:30pm |
That's a good one Mooses.
Dane and Donna Smith
