  New Posts New Posts RSS Feed: Water heater
Topic ClosedWater heater
wrbrown View Drop Down
Direct Link To This Post Topic: Water heater
    Posted: 04 Jun 2014 at 9:45pm
Thanks everyone for the reply. It was what I hoped to hear.
Seanl View Drop Down
Direct Link To This Post Posted: 04 Jun 2014 at 3:19pm
The antifreeze is non toxic for the most part so as has allready been said flush it out and your good. It tates bad.
Direct Link To This Post Posted: 04 Jun 2014 at 9:19am
Yeah, just flush it out real good and you will be fine.
kymooses View Drop Down
Direct Link To This Post Posted: 04 Jun 2014 at 8:56am
you're fine.  no harm no issues there.
the only reason water heaters get bypassed is to save from having to use so many gallons of antifreeze that you'd have to fill the hot tank first in order to then have it to the hot water lines.
you're good to go.
Direct Link To This Post Posted: 04 Jun 2014 at 12:00am
When I winterized the water system some antifreeze got into the hot water tank. I guess one of the valves either leaks by or it was not totally closed.
I discovered this when I pulled the anode rod for inspection. It was only a cup or two that came out. I flushed the tank after that. Does anyone know if the antifreeze could have harmed any thing ??
