  New Posts New Posts RSS Feed: 2011 R-pod 176 toilet flushing water issue
Topic Closed2011 R-pod 176 toilet flushing water issue
Wen View Drop Down
Direct Link To This Post Topic: 2011 R-pod 176 toilet flushing water issue
    Posted: 02 Dec 2014 at 8:07pm
thanks for sharing your experiences, probably I can do something little tricks like you said, haven't tried anything yet,
Outbound View Drop Down
Direct Link To This Post Posted: 02 Dec 2014 at 5:21pm
Yes, it happens to me every now and then.  Its likely just some debris in the lines.  Usually, after a drive, it'll work its way out on its own.
There is no flow control on the toilet.  If you're feeling adventurous, you could try shutting off your water pump, carefully disconnecting/unscrewing the feed line to the back of the toilet, and turning on the water pump again to 10-20 seconds.  Prepare to get the bathroom quite wet.
Wen View Drop Down
Direct Link To This Post Posted: 02 Dec 2014 at 4:18pm
The past thanks-giving break we gave our new bought used 176 the first trip, not far 100 miles away, kids are happy and we too, Tongue
During the time we found the toilet flushing water flow is kind of very slow, the kitchen tap water on flip side cold or hot has lots of pressure more than the toilet, water pump will kick in each time and the toilet flow slight increase, but never to same level as tap, not sure if any of you experienced similar issue? Is there any way to test or tune the toilet?
